-:|Update - 2010-01-23|:-
I had a little mishap today...again. But this time my supra got damaged
I was stitch welding under the passenger side while being a bit irritated on
the lamp, which I couldn't get to light up the area I was working on and not
activating my welding helmet at the same time.
So when I was done on the passenger side I just crawled to the driver side
and continued there. After awhile it felt very hot, to hot to be from welds.
"Fire!!!!" came to my mind and I'm afraid I was correct
The carton I had used to protect the windscreen while working inside the car
had been placed on the driver side floor. So that started burning from the
heat and was completely gone when I looked in.
The fluid that was closest to me was Sprite, so that had to do, I used that
to put out the fire.
The things I need to replace (If you have one or more of these, please let me know):
Combination switch
The light for the ignition
The switch on the side of the ignition lock
and maybe a door panel
I will also have to go through the wire harness to see if any wires are broken.
The tape covering the harness to most of the damage.
I might just change all of them and skip the ones I don't need.
The door panel got burned. If you look at the picture of it, is it repairable?
or should I just get a new one?
If you have any of the parts that I need, please let me know, thanks.
Pictures:
After I put out the fire, it looked like this
The combination switch which needs to be changed
The half that controls the light is not damaged
Neither is this part of it
The light around the ignition is unusable
The part behind the ignition looks ok
This is the switch which sits on the opposite side of the ignition from the push button
After some cleaning and removal of damaged parts
The damage on the driver side door panel, fixable?
