CLEAR REAR INDICATOR CONVERSION.......
willfish
been here since 2003
Apr 23, 2005
648
Pittsburgh, Pa.
stanzaspeed said:
Id almost like a pair, but it would just look wrong with a green car :biglaugh:
they will look badass on your car. They really look awesome on wills car!
no man, get yo self a set, , honest, clear with green paint,, I can dig it...
the clear to me is like a nuetral color, it would go wioth any color... not like your getting a set of blue tails with green body paint,...
know what I mean ?
Will
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
maby ill look into it once i pick up my new turbo / mani etc. I need to get my ass back to work first! :rofl:
wolfie308
Lensmeister
Sep 5, 2006
92
Bucks, England
www.protocast.co.uk
Morning Guys,
And first thanks for all the positive comments and interest. To try to answer roughly in order, the lens shown was taken from the rear cluster which fits an '89 U.K spec car. Unfortunately, not having done this before, my friend destroyed his spare set in the oven in order to extract the amber parts. I was told that although there are differences between the ealy and late model units, the inner amber part appeared to be the same. I don't know if that's true and whether there are differences between U.K/ Euro spec and U.S / JDM units.....all a bit of a minefield
Although I have a lot of experience with various Toyota front and and rear units including the Celica ST202 and 205 fronts - these are quite easy using the oven trick. The Corolla '85 rears as used on the late model Lotus Esprit need a different technique involving immersing in a bucket of near boiling water !!.......trust me it works - it's how I got the master to make my clear indicator conversion. Click on the links below and you'll see one of the cars that now sports my exclusive rears - looks so good I could lick it all over :icon_bigg
http://i44.photobucket.com/albums/f11/wolfie308/EspritAlexsbefore058.jpg
http://i44.photobucket.com/albums/f11/wolfie308/Espritwithclears0091-1.jpg
http://i44.photobucket.com/albums/f11/wolfie308/Espritwithclears012.jpg
However, when it came to the Celica rears, I was defeated, as what I thought was black trim round the outside turnd out to be part of one single lens including the amber, red, and clear reverse parts.
So.........I'm waiting to get hold of a used maybe damaged unit that I can try different techniques on and then photo and document the procedure if I'm successful.....fingers crossed.
I was also considering doing the front indicators for the late models as I understand they can be difficult to get hold of. The ones I've seen are the 'crystal' clear type which I personally don't like and don't think suit the original styling cues of the car as well as an exact OEM copy would do.
Here's a pic of my Celica fronts which show the incredible detail that I achieve in the moulding which is similar to the look I had in mind for the Soop
[/URL][/IMG]
Be interested to hear what you think, bearing in mind the price would be in the £65/pair region.
Regards side repeaters/ side markers, I am awaiting a side marker for a U.S Elan which I intend to try cut apart and cast both parts in different materials then rebond/glue them together. This will be tedious and not cheap as I'd need to make 4 moulds just for one set units. Then there's the question of do I do the flat U.S type or the Euro type with the bulge ? Best let's see if it's worth me doing in principle first.
Will keep you posted of progress or more likely back shortly with some questions
Richard
www.protocast.co.uk - Clearer by Design
SacoMan
56
Spain
www.supraclub.es
Im interested, but dumb photobucket is in maintenance and I cans se any of the pics!!!!
****Fixed****
they look excellent I want some, fronts too!!!!
wolfie308
Lensmeister
Sep 5, 2006
92
Bucks, England
www.protocast.co.uk
suprahero said:
Clear front turn signals would be dead sexy....................lol
For the Esprit or the Soop? :icon_bigg
Just knocked up a housing out of cardboard, sprayed it chrome, then set against a black bacground, took a couple of pics on auto and you can see from the links, one with a standard amber bulb and one with a 25 LED cluster bulb. I'm not easily impressed by my own work, but I have to say I think these are looking hot......IMHO :evil2:
http://i44.photobucket.com/albums/f11/wolfie308/Suprarearclearlensamberbulb.jpg
http://i44.photobucket.com/albums/f11/wolfie308/SupraclearrearLEDbulb.jpg
Hopefully this'll give you a bit more of an idea of what the finished look might be like. Work still in progress to source a complete unit to check my surgical skills.
Richard
spinningheadboy
Ich bin gegan alles
idaho
The U.K. MKIII supras all had the 86.5 to 88 rear turn signal units, the 89-92 USA spec lights never made it on the late supras because of the license plate requirements and fog requirements for European supras. This reflector is for 86.5 to 88 USA tail lights only.
I think a clear Bulge/bubble side markers (And usa spec flat ones) in clear would be a very good seller.
Figit090
Fastest mk3 GT4 1/4 mile!
Jan 7, 2006
1,835
Humboldt County
I have an 86.5 and i would LOVE to buy a set of clear fronts, which BTW i think you could sell a LOT of... i dont know about the rears though... i'd like to see the older style rears without the orange....then i'd decide. sounds cool though!
wolfie308
Lensmeister
Sep 5, 2006
92
Bucks, England
www.protocast.co.uk
xrated89 said:
in the 89 and up you can just remove the amber piece :p just to let you know
Cheers for that chap,
But now I'm getting very confused :icon_conf . Are the early and late models different in their construction? How easy is to remove the amber piece?......my mate overcooked his in the oven in order to split he case apart. Are the amber inserts possibly the same even if there are other differences in the units?
just removing the amber alone would IMHO look like somebody had smashed you lens.......not quite the effect I had in mind :nono:
So I'm still waiting to get hold of either an early or late model unit for close inspection - I am at a distinct disadvantage to you guys as I don't have one on my drive
Anyroads, there seems to be enough interest in the side indicators for me to have a look at those. I have one bubble type which my mate sent me - I'll just check with him that it's okay for me to try cutting in 2 which is the first stage.
What I had in mind was to use my Dremel in its pillar stand, then I'd have to buy a right angle attachment and then fit a thin cutting disc. Guess I'd need to ake up a small jig to hold the unit square and feed under the spinning cutter.......is the theory.
Got one in front of me now........and looking at it, it doesn't look a lot. However, if I can make a factory looking replica out of 4 bottles of liquid and some sticky stuff, I'm a freakin' wizard !! Let's see how good this boy is :evil2:
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
I've got an extra set of side markers. I once tried to pry the lens off the backing and it has some insane glue on there and would have surely broken apart before splitting. Perhaps if we could donate a couple of pairs of these to you, you could carefully cut out the part you need from each peice, giving you the 2 moulds required? I'd chip in my extra parts for the project.
wolfie308
Lensmeister
Sep 5, 2006
92
Bucks, England
www.protocast.co.uk
Cheers Buddy,
And thanks for the offer. Actually, I reckon they aren't glued, but pressed together whilst one or both is still hot and soft.
Cut the lens off the backing on one and the backing off the lens on the other......good idea but hugely more work. My plan is to get the cutting wheel set up and real carefully run the unit in the jig under the disc along the joint seam. I may need to shave 0.5 mm off the bottom of the lens as I cut, but I don't think that'll matter. Once the 2 cut surfaces are cleaned up, I can check the fit before making the 2 moulds.........well that's the plan anyway
http://i44.photobucket.com/albums/f11/wolfie308/Suprafrontambersideon.jpg
xrated89
120
Canada
i dunno about the older ones but the new ones i pryed them out was a lil bit of work but not to bad I have the amber pieces out of them if anybody did want pics or anything
