There are two studs that stayed in the head should I remove and helicoil them or leave them alone? I remember seeing there is a double nut method on removing studs you put one nut on then tighten another one on top of it then that will allow you to loosen the stud.
EDIT: I removed the studs using the two nut method, tighten the nuts onto each other and loosen the stud, I drilled out all of the holes except for the one at the back near the firewall, the drill bit is a little too long so I have to get a reduced shank bit I see why you guys said to get that but I didn't realize how little room there would be. So far it is going well I already got one hole done then I decided to drill them all then helicoil them all to make things move a little faster.
