Chambers Build Thread - "Daily Eighty-Seven"
Chambers
Now you know
Sep 9, 2007
981
Baltimore County, Maryland
Initial measurement showed 1" front and .5" rear, its great, it still looks like stock suspension but gives a lot better feel and look than the stock springs did. I guess its sits about as high as my stock 89 did. After putting almost 18k miles on this car and working on it all the time, the 1 and .5 was more than noticeable. The engine bay requires a little more bending to get to now.
lithium14
995
Austin
wow... that actually sounds perfect to me, the streets round here are not conducive for slammed status... thanks man!!!
Chambers
Now you know
Sep 9, 2007
981
Yea, for a daily driver super low is not good.
Got an update, got my wheels mounted with tires. Had to order hub centric rings that were Toyota-Ford.
Chambers
Now you know
Sep 9, 2007
981
Thanks.
On my way home last night i heard a "POP-PSh" I thought it was one of the other cars around me but when I went out and started the car this morning the clutch pedal went to the floor. So this will be the second failure I have had with the Howe throwout bearing, I have a spare Howe unit that I'm going to use to get to the meet down in VA but dam, I need to upgrade...
RedPhoenix
Kill it with fire!
Sep 23, 2009
222
Tampa, FL
No idea what it is with those Howe bearings, they are just garbage. We are not the only ones having issues with them. A lot of Neon guys are too.
Chambers
Now you know
Sep 9, 2007
981
Worked on the oil cooler today, got it mounted primed and pumping. It seems to be working great, other than a small leak at the connections on the cooler, Just got back from a run around town so when it cools I'm going to put a little more torque on them to see if that solves the issue.
Also put in a tach driver from a 89 Celica, it just about bolts right in. The only weird thing is now the needle jumps when I hit just about any electrical switch in the car, maybe the Celica driver needs the tach motor as well? Or maybe there is a noise filter that the Celica has but the Supra does not. I'm not sure but I was able to drop that honky tach on the dash so now it looks absolutely factory.
And I have a few random recent pics.
7M-GE w/ Auto Trans tach:
Celica tach driver:
Celica tach driver doent mount to the tach but still bolts onto the cluster:
Thanks for looking!
Chambers
Now you know
Sep 9, 2007
981
Yesterday I modified the stock mount for the Charcoal Canister and got it mounted and plumbed. I also unplugged my MAF and plugged it back in and the hesitations has seemed to diminished drastically, so I pulled it apart again today and cleaned the pins with a Emory board, I'm going to go see if it made a difference here soon, and finally I cut down the stock glove box liner so the little light would have a place to live and the latch would close and release correctly.
Chambers
Now you know
Sep 9, 2007
981
Well... There goes another... Slave cylinder that is... Clutch was slipping today, lucky I made it home before the clutch pedal didnt return... So now I will upgrade to a Quarter Master slave cylinder and see how that goes...
