Thanks, with the spacer from the Quantum-Auto kit I didnt want to change out throwout bearings and have to deal with shims and all that so I just kept using the Howe, but now I'm going with the QM unit with a new spacer from QA, they are the same but I wanted a new one for the new unit.
Small update, pulled the trans, the brake fluid began to dry up and "oxidize" it was all over the inside of the bell housing, after a little cleaning with PB orange degreaser it started to clean up well. I removed the Howe unit for the last time, good riddince... Then pulled the engine to swap manifolds, so far the o2 sensors need to be relocated and new engine mounts may be needed to fit the 3" down pipe between the frame, exhaust header, and engine mount, our first attempt at this failed, the engine sat to far up and to far over to the drivers side... back to the drawing board... Pics:
Holset Supra Mafia?
Holset Supra Mafia?
