CajunKenny's Build Thread
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
Thanks! Yeah, that DSM is currently down; but, will be a little more of a beast when it's back on the road. I'm sure it'll be a little harder to catch. :)
CajunKenny
Nov 15, 2007
3,255
Washington
$275 is hard to beat!
Well, here's a tip that I noticed between the street and the dyno. There is roughly a 1.0 difference in AFR between the street and the dyno.
Example....if you tune on the dyno first, be prepared to be about 1.0 RICHER on the street. Not a big deal... However, if you do any street tuning, be VERY careful when on the dyno because you will likely be running 1.0 LEANER. Not good!
Other folks may have had a different experience; but, this is what happened to me. So, be careful! :)
CajunKenny
Nov 15, 2007
3,255
Washington
Yeah, at first I thought it was a fluke. You know, temperature difference or something similar. But, it happened a second time. Kind of scary actually...
IBoughtASupra
4,455
Queens, NY
Nice Job Kenny. Stock Internals and stock head right?
Mike, your using 2JZ coils? The coil setup on the GE or GTE? What are you tuning with since you didn't get the MAFT-PRO?
CajunKenny
Nov 15, 2007
3,255
Washington
Yep. Stock head and internals.
Probably the only thing different from everyone else is that my Intake Manifold has been Extrude Honed.
Thanks again Fred! :)
CajunKenny
Nov 15, 2007
3,255
Washington
Well, my ride FINALLY has a lip!! :D
Here's the test fit. Note the two clamps holding it in place.
And here are a few different angles of it all mounted up. The passenger side is perfect; but, the driver's side needs a slight adjustment. I'll get to that when I pull it off to paint it.
CajunKenny
Nov 15, 2007
3,255
Washington
whitemike;1569187 said:
Why do you have to be in exactly the furthest point away from me in this country? I would so love to see this vehicle
I guess it's time for a road trip!! ;)
djordan97;1569445 said:
cause it's the best place in the country
Considering the wind we have here....that is slightly arguable. :biglaugh:
