Bolt on Big Brake Kit For around 300$.
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
why does it look so bad like there is a huge non contact area on the picture posted above somewhere.
I'm on cobra breaks, and I have made them fade at the track. All the talk about cross drill being no good.. Why are all porsches, and even my IS-F drilling rotors? Looks? Are you 100% sure on this?
D.J.T.
877
Arkansas, United States
Just picked these up for $30 after tax from a local salvage. Off an 02 S430
Grandavi
2,664
Calgary, Alberta, Canada
Unless they are forged that way. Yes. Google the question.
midnight_mk3
53
Staten Island, Ny
I just installed this setup on my soarer and everything bolted up perfect but my wheel (17x8 +35) would not clear the spokes.does anyone know if na mkiv fronts will clear? Or maybe sawblades with a 5mm spacer?
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
all rotors are cast andthe holes are drilled afterwards. no rotors are cast with holes, this would be virtually impossible. drilled holes are simply chamfered to minimize stress. and yes, oem drilled rotors will certainly crack from the holes.
ghynes440
52
Pennsylvania
I cannot seem to find these on eBay anymore! IF anyone can help Id appreciate it. Some are listed as 00-06 calipers are these still the right ones?
MKIIINA
Destroyer of Turbos
Plano, TX
Anyone have the part number for the caliper fitting for the brakeline? Seems mine didn't come with a 90* off the caliper, just a threaded hole...
suprajim54
119
Dallas, Texas
Mine was the same. I re-used the stock banjo bolt and fitting on the stock brake lines but they seemed too short or too kinked and I couldn't reattach the small 2-bolt bracket that mounts to the hub/knuckle. I ziptied the bracket and bled the brakes enough for a quick test drive before replacing with Goodridge lines. Same thing on those, a banjo bolt and fitting that will thread into the Merc calipers. They're a little longer than stock lines so I was able to put the factory brackets/clips back in place. I found the brake lines were the only confusing part of this mod, but in the end it worked out for me.
Dm also sells some longer brake lines that are used with the cobra bbk. Used those on my friends car and everything bolted up.
jshjuarez
Hey guys I'm sorry if I ask a question people have asked but what rotor fits with the sclass calipers that would with 18x9.5 rims with a +22 offset
What pads are you using?
Oem Mercedes pads usually don't squeak.
If they were new maybe you didn't break them in properly?
