Bolt on Big Brake Kit For around 300$.
Dec 13, 2006
Illinois
^^^^^You don't need to laugh at him or be unruly. He may have just not included the hub centering rings in the video by accident. At least he's putting an effort into providing these videos. He also did a fine job in giving everyone they're deserved credit for the research. Take it easy... it is after all called poor man mods, not deep pockets mods. different strokes for different folks.
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
sorry i was a little harsh but really he should do more research and be positive he knows what hes talking about then before making a how to video.......it wouldn't have cost him any more getting the recommend rotors like everyone else that are 13" have full pad contact and are spaced out right to fit the caliper without grinding. and you can't just use any old bolts for brakes they're always grade 10.9 or grade 8 or higher. being iffy on engine mods is one thing but brakes suspension and steering need to be taken seriously and done right cause a failure can be life or death where as if you do something wrong and blow up your engine you just cry but can walk away. and he was straight wrong about the cobra brakes. i just think if you're going to spend the time to make an informative video take some time to get your facts right!
Nick Squire
80
Montreal, Quebec, Canada
that's the same guy i bought mine off of, same calipers too. He definitely noticed them being bought up more and more recently and upped his price because I noticed they started from ~75 and have climbed to as high as ~150
Those are not the correct calipers. Look back a couple pages.
They have gone up in price because everyone just started buying them up like crazy.
themadhatter
760
Vegas
The soarer got some brakes this weekend
bluebullet89
192
Meridian, ID
whats wrong with slotted AND drilled? or just personal preference.
AND... is anybody finding the EVO brembo rears for a better price than $200 a set?
Grandavi
2,664
Calgary, Alberta, Canada
Slotted and drilled are for brake pad material used about 40 years ago. It allowed trapped gases to escape. If your going BBK you should be concerned with maximum effective pad contact area. Slotted and drilled are not good as they reduce contact area and add stress points that shouldn't be there. Aesthetically they look cool. But that's it.
They aren't as effective or safe
Grandavi
2,664
Just to put this to rest... (The slotted and drilled rotors) someone explain why companies sell these? With present day brake pads, gases are no longer produced... So that argument doesn't work. Heat reduction? Less surface area = less thermal transfer... So that doesn't work.
Only a few very high end manufacturers actually forge the slots and holes into the pad... The rest are machined. That leads to a high potential risk of cracking...
So why do people like SPRacing say they are better and then use the 60's brake pad characteristics to explain why.
Confuses me... Do I have it wrong??
bluebullet89
192
Meridian, ID
Nick Squire;2054188 said:
I looked into the evo rears, decided I'd wait until next year lol, the rear setup was going to cost me more than the fronts did!
ya. :/ i havent dropped the money yet for rears simply cause a set of calipers is so high. got to be cause they are from an "EVO".
I just purchase Power Stop Rotors, i have the calipers and just getting the last few things to get it together.
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
I have always been under the same impression that slotted > Drilled >>>>>>>>>>>>>>>>Drilled and Slotted. For the reasons you mentioned. Having them drilled OR Slotted is beneficial for heat and pad dust distribution but having both decreases surface area and strength.
Seems like the general consensus is slotted is slightly better for stopping power/heat distribution but will wear pads faster than drilled but both pretty good options.
And its always annoyed me that it is so difficult to find slotted only options or even drilled only in some applications.
Nick Squire
80
My rear rotors and pads are getting tired but I'm gonna try and stretch em till next year, simply because I'll have the winter to find a good deal/save the extra cash for the evo set up...I mean they are ONLY rear brakes, not like we need em
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
Anyone have pics of the brake line connected to the Caliper ??
FYI- if anyone interested, i might be looking to sell my calipers with HUB rings.
Grandavi
2,664
I personally would only use non-slotted and undrilled on our cars. Slotted have a ridge which reduces pad life and removes (slightly) contact area. Our pads do not need a "gas release" area. Most of the slotted/drilled benefits are a myth... But they do look cool.
