I'm interested in seeing where the test data leads on what makes up this product.
If it's a chlorine, did they figure out a way to process or treat it so you end up with long chains that do not vaporize as easy as the shorter ones? (Much like synthetic oils from what I understand.)
Or is this complete bunk? I suppose the testing will show what's up. (Or in this product anyway.)
Just a thought. If you used this stuff in your oil, and then changed your oil every 3,000 or 7,000 or 15,000 miles... would there be enough breakdown of the product to produce enough acid to become problematic v/s the benefits of the better lubrication properties before the stuff breaks down?
Not to be the devil's advocate, but most people rarely run their oil much more than say 5,000 miles. (There are a few who never change it, but no addtitive package will help those motors IMHO.) If they drain out the broken down acid with the normal oil change, and then add the bi-tron every 10k as reccomended, perhaps that's enough to provide the benefits of the chlorine based lubricant with out causing acid problems in the long term? (And thus the reason people who use this stuff like it, they never see any problems from acid damaged parts in the engines.)
I would think you would want to run a diesel oil to keep that acid under control as best as possible right? (Rated for CF.)
I'm not an oil expert, and I'm very interested in seeing how the test data turns out.
I also do not use this stuff in any vehicles I own, but have been watching the debate here with intest for awhile now.
If the test data shows this to be some stable form of chlorine based lubricant, I will add it to my cars no problem, and contiue to change the oil twice a year, and use a CF rated synthetic, or blended synthetic oil depending on the vehicle. (My motorcycle runs the Rottella T Synth as I change it every 1500 to 2k due to the oil being used in the gear box. Some cycle tests have proven that bikes are quite a bit harder on oil than cars, and oil shear in the gears I assume wipes out the viscosity pretty quickly.)
I've run Mobile One for years, but I'm changing over to Redline as it appears Mobile has started to blend a group III oil into their synthetics... damn them.
For quite a few years I ran Shaffer lubricants, and they had/have a diesel rated oil that is green. Great stuff. Don't know if it was full or blended synthtic, but on our service trucks, and my own personal cars, it worked great, and kept the inside of the engines spotless! (Not available here anymore, so I stopped using it.)
Please get that testing done ASAP
