The Bi-Tron lubricants are extremely similar to Prolong, which is a publicly traded company, having gone through many lab tests as posted on their site. To prove that the things I am describing are not so far-fetched, here are some exerpts from their website:
"Prolong's AFMT technology doesn't just enhance motor oils, transmission fluids, gear oils, and other lubricants. The patented AFMT formula
actually treats and modifies the surface of the metal. AFMT is a highly specialized extreme-pressure property lubricant that is formulated by chemically treating paraffin-based hydrocarbons, known to be superior lubricants capable of withstanding extremely high temperatures and pressures. Prolong AFMT is formulated with
a unique long-chain molecule achieving significant chemical stability. This process is patent protected and is so stable that it is responsible for achieving the highest possible "1a" rating in independent laboratory testing designed to determine the anti-corrosive characteristics of lubricants.
Motor oils, transmission fluids and gear oils are flowing lubricants that provide a film barrier between metal surfaces pressing or rubbing together. The greater the film strength, the better the oil. However, in extreme pressure metal-to-metal areas, the film strength of oil is seriously thinned and is often completely squeezed out.
On the other hand, Prolong is
a bonding lubricant. Prolong AFMT interacts with metal surfaces in a molecular and chemical process to create a protective buffer on the surface of the metal. This is not a film or coating over the metal. Molecules in the AFMT formula are polarized and actually bond with the metal surface. The layer of AFMT molecules is activated by extreme pressure and heat, meaning that Prolong lubrication performs best right where it is needed most!
