<bought up to date for Joe>jetjock said:Lol. "One head bolt...two head bolts Yo sucka..."
SupraSabre said:I know that they are very expensive for some one on a budget, be sure to put ARP head bolts or studs on your list! And clean out the block threads really good. :thumbup:
And throw your old ones away.
cuel said:Just to mill it, around $40. To check it for cracks, clean it, valve job, etc., costs more. Manually cleaning the block should be fine, as long as the deck isn't severely pitted. I wouldn't take sandpaper to it, as its possible to create low spots. A scraper should get you by just fine. If you hit a stubborn bit of gasket, try soaking it with PB Blaster for about ten minutes, then scrape it again.
suprarx7nut said:I was under the impression headbolts were torqued to an amount that did infact cause mild yield or at least enough stress that they should not be unloaded and loaded again, maybe even beyond the original stress.
Although my motor has had 4 HG's and I'm not sure new Headbolts were used on any so I will not be risking using the old bolts.
cuel said:Here's where the TSRM details installing the head. http://cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=EM&P=55 I don't see where it says to use new bolts?
