WOW why are there so many people saying not to reuse the stock head bolts? the TSRM specifically does NOT list them as a part to replace in this ordeal. I went through this SAME debate when I did my BHG fix and ended up reusing them. This is the second time they've been reused if they were reused when the original owner blew the headgasket, and i have about 2k miles on the engine since then. Plus I was a beginner learning as I went with help from people on these boards (thanks again guys).
I can show you my thread later if i can find it. its pretty long though and i dunno if you feel like reading it...if you do let me know.
A good machine shop will put your (engine) head in a hot bath or chemical bath to remove ALL the carbon and oil. you can then have it checked to see if you have leaks and need a valve job, and they can do all that for you. Then they can check it for warping and refinish it. If i remember right, my head cleaning and re-surfacing didn't go above 60 dollars. A quick pressure check was free on the valves. hopefully you checked to notice if you were burning oil before this, but if you have a lot of miles on the clock new valve stem seals isn't a bad idea. i wish i put them in but i don't really burn oil with 111k miles on my engine so at least that's a bit on the bright side.
I used a toyota OEM gasket set on my engine, scraped the block with a razor, got the head done, did misc. cleaning and such, stuck it back together, and it seems to be OK! I see my temp guage go up a little now and again but i'm not consuming coolant and i think i have a little air bubble right now. in combination with absolutely NO OEM shrouds...i dont think its a BHG. i need shrouds....
but yeah dont take the head apart unless you know what you're doing. and if you haven't already - keep your lifter pucks and cam bearings are removed and replaced IN ORDER or you will have to double check that they all fit properly within spec when the head is reassembled. I think the cam bearings are numbered but of course the pucks are not. machine shops should take the head with this stuff removed, maybe even less. if you've removed more just take it how it is i guess.... dont bust your ass when a tech can pop those out in seconds.
I didn't bother - but one thing you can check upon reassembly is cam bearing clearance. I did however check my lifters to make sure they were not too tight. they were a bit on the loose end of spec, and they tick now, but they are still fine. but if you want to avoid a little ticking, you can spend a few dollars and get new pucks that will stick you within spec. you'll have to do measuring or pay the machinist to do that though.
best of luck with all this.
OH and another thing - PLEASE consider heli-coiling your exaust studs. If they are not done I can almost guarantee you will strip at least one out, most likely in the back by #5 and 6 exaust ports. this is in my BHG thread too i think. I didn't do them (as per my machinist's suggestion) and ended up buying a new angle drill and helicoil kit for doing it IN-CAR once the head was on. one of the worst feelings i had while doing this was getting it all on and then feeling that exaust stud begin to pull out as i got the exaust on...
Best,
Andrew
