Anyone running a GT35R on a 7mgte
WeDgE
Buh-bye 7M...
Jan 2, 2006
495
Alberta
IJ. said:
Cliff Notes:
GT3540R + 3.0L + 25 psi = 500ish RWHP and much goodness
GT3540R + 3.0L + 30 psi = 530ish RWHP and some extra Intake Heat!
How much more RWHP would you see using gasoline instead of LPG (I saw that you said LPG makes less power than petrol?)?
WeDgE
Buh-bye 7M...
Jan 2, 2006
495
Alberta
I thought the T4 flanged 35Rs only came in 0.70A/R turbines?
EDIT: Whoops, I messed that one up! Looking to get the 35R with a T4 flange, V-band outlet and 0.82A/R turbine.
8,898
Where do you plan to get a T4 flange?
87_7MGTE
SOLD :(
Bellingham, WA
tubbie said:
87-7m: What psi did you dyno 450 with?
18 psi, because i also figured 18 psi was safe.
Shooting for at least 500 rwhp when i get a good tune and put my ffim on this winter, and also up the psi a little.
Silvermk2
MkII Weenie
Apr 4, 2005
99
Stockton, CA
Hopefully I'll have mine dynoed in the next couple of weeks before Vegas. All I know is that at 15 psi (no boost control) it screams in the MkII. I get 15 psi at around 3200-3300 RPM
Racefiend
OH, YEAAHH!
Apr 6, 2005
106
Bay Area, CA
Sweet! Finally got it one eh? We must meet up so I can check it out :)
87_7MGTE
SOLD :(
Bellingham, WA
drjonez said:
dyno sheet? curious about spooooool.
what turbinge housing as well?
yeah... about the dyno sheet. the reason i havent posted it is because its real ugly. i need to pull fuel out down low so it spools faster. plus the inductive clamp for spark on the dyno wasnt working well that day, so it makes it even uglier. ill post the sheet when i get home.
.82 a/r housing
450hp/457 tq UNTUNED
