from reading figgie's post on it. it sounds like you can just change the mapping to run gas or alchy.
Adjuster said:Actually, on Maft-Pro, you should just be able to change AF needs, and let your WB do the tune based on what fuel your running right? (The stock NB would be screwed, but most WB setups give you the right range for either fuel, you just need to know what AF to run for no load, medium load and WOT load for each fuel.)
Well, and change over to parts that support the fuel and flow the amounts needed.... (For me, right now, Costco 91 octane at less than 3.00 per gal is ok as long as it's mixed with the 114octane Toulene I bought for about 1.30 a gallon years ago in 55gal drums... ) I run about 20% all the time, and go as much as 40% when taking the car to the dyno or drags where I might be tempted to turn up the boost more
20% toulene handles boost to about 25psi pretty well.
40% handles boost above 25![]()
