Alternatively fueled supras
figgie
Twin Cities, Minnesot-ah
IJ. said:
:) Even pushing it pretty hard I can still get 400>500 KM/ 250>300 miles per tank!
Not bad for this sort of power output!
outstanding :) I am still running the stock 16 gallon tank but the cooling aspect of the e-85 and the timing advance works to bring the mpg to with 5% of Gasoline which is not bad. The BAD part is the damn fuel pump needed to run alot of HP. Has to be STUPID big ;)
1) Remove Gas system
2) Install LPG tank (pre filled with 20 litres)
3) Install Gas Carb
4) Install Convertors
5) Plumb lines
6) Wire up the Closed loop controller
7) Wire Gas gauge
8) Tune
9) Get scared and limit boost to 20 psi ;)
N
NDBoost
Guest
3) Install Gas Carb
5) Plumb lines
7) Wire Gas gauge
8) Tune
sounds good, ill have to read up about it more on google. Its a definite project id like to invest in :biglaugh: :naughty:
Here it used to be a bit hard to find so if you had an LPG only car you had to plan trips carefully but these days 90% of filling stations have LPG.
For a long time I ran the Supra as a dual fuel system so could switch to Gas if I ran out of LPG.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
this is very interesting, i thought about doing this and i prolly will in a couple of years when they will prolly have more stations around here ( i think there is only 2 in the denver area)
Thanks Rich!
Doing the conversions that's 97c AUD a litre which for us is really expensive as today it's just on 50c AUD a litre!
I guess it's a supply/demand thing and if it's not as common there they can screw people :(.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
LPG is down in price here now to $1.65pg, but i think it goes up again in summer for all the campers and bbq's.. may have to reasearch it some more. stockpile fuel for summer lol
got any piks of your GasResearch Carb
Joel: That's still 60c AUD a litre :(....
It's really difficult to "stockpile" as you need a pump to transfer it from the holding tank to the vehicle!
This also means running out is a bitch in an LPG only car!
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
ya thats a good point, atleast around here most gas stations and hardware stores have a lpg tank. you mean a bitch like when you run a diesel dry??
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
got ya now.. ive never actually run out of gas. but i bet that would really suck.. i was thinking standard tank sizes and quick connector and just swap out tanks for the stockpiling of lpg..... ;)..
run 2) 10 gallon tanks..
