So I get home one day, and my supe is having trouble.
Been havin probs for days already, luckily my 7m is built like a tank.
I know already that usin old parts can be a problem.
Been lookin around for days, just cant get in touch with the right person.
whaduya do when the stock stuff is just not avail?
:evil2:
U P G R A D E !!!!
I didnt wanna get this much stuff so soon. but i cant find any suitable parts to get back on da road. But when a kit has all this, it can be worked with.
peep this "kit" from ebay:
(this is copied from the auction)
:icon_arro
TURBOCHARGER SPEC
1) Compressor casing: A/R.60
2) Turbine casing: A/R 1.15
Max Speed( r/min): 130,000
Max Durative Working Temperature(℃
: 800℃
Max Temperature of inlet gas in one hour(℃
:850℃
Max Rate of Compressed Air(πc): 3.0
Range of Fulx(kg/s): 0.115-0.396
Suited Power Range(hp): 450-600 hp
Cooling: Oil cooling system
Bearing: Dual Flowting bearing
:icon_arro
Wastegate Spec:
Race 50mm External wastegate.
made with high grade iron cast
boost adjustable by boost controller
8.7psi setted
:icon_arro
Manifold
manifold constructed with full stainless SS for the highest quality and duration.A perfect match to Garrett T4 Turbocharger or Garrett turbo kit setup.All Manifolds are made from stainless steel mandrel bent pipes. Great care was taken during the design to enhance the performance of your normally-aspirated conversion or Turbocharged upgrade vehicles,2.9mm Wall thickness and by fine-tuning the placement, size and angle of each collector to even out the exhaust pulses. Combined with large primary runners makes Exoticspeed manifold a solid choice for your vehicle.
cracking against for life.
(ALL GASKETS AND BOLTS ARE ENCLOSED)
:icon_arro
Turbo XS Sty Super Sound Type H BOV
100% BRAND NEW IN STOCK READY TO SHIP
100% HIGH GRADE ALUMINUM
SUPER LIGHT WEIGHT DESIGN
LARGE TRUMPET FOR SUPER SOUND
DIRECT BOLT-ON FOR ALL TURBO APPLICATION WITH FLANGE UNIVERSAL FITTING KIT
HOLD UP TO 1200HP OR 35 PSI OF BOOST PRESSURE
ONE PIECE CONSTRUCTED (PERFECTION GUARANTEE)
COMPLETE BOLTS AND GASKET ENCLOSED
FULLY ADJUSTABLE PRESSURE
:icon_arro
Silicon Hoses And Clamps Kit
2.5" x4 Silicon hoses (high quality in blue)
2" x1 Silicon hoses (high quality in blue)
9 x 2.5" clamps
2 x 2" Clamps
:icon_arro
INTERCOOLER SPECIFICATION
23"X12"X3" INCH TANK TO TANK
16"X12"X3" CORE TO CORE
All parts are 1 year warranty from UNIQUE JUST
Final sale only,No refund,exchange.
