87' 2jz gt47-88 MK3
Janz99
234
Winnipeg, Manitoba
Who says you cant fit an 88mm turbo in an mk3 without cutting it up :)
The header i built for it:
Enjoy!
Ryan
Janz99
234
Winnipeg, Manitoba
Yes, i made the exh. manifold out of 304 stainless, as well as the collector. The head flange and collector flange are mild, to keep warpage down. The disty is ditched in favor of a COP setup. As for the downpipe, it might look alittle decieving in the pics, but there is room for the 4" piping to squeek by!
Ryan
mdr40z
arkansas
cool, somebody's got a lot of work to do still, looks great so far...... is that a TH400 bolted up?
Janz99
234
Winnipeg, Manitoba
No, its a powerglide in the picture, but i decieded to put a th400 in the car instead. There is still alot of work, but its slowly finally starting to come together!
Zer0DeGreeZ
287
N. KY
Mad props. Your certainly on your way with this setup. I assume your going to do a bit more welding on the manifolds, and probably dip em in some sort of coating yes?
Janz99
234
Winnipeg, Manitoba
Yes, the manifold is only tacked together. It still needs to be finished welded, and the dual wastegates setup. Im waiting to do the gates untill after the header is completly welded, because im anticipating it to warp/move alittle once its welded.
Ill probably run the manifold for a year to make sure everything is leak free, and that i wont have any issues of it cracking. Then ill have it ceramic coated,.
Ryan
PureDrifter
VIP Cruisin'...
Aug 11, 2009
317
CA
www.clublexus.com
damn this will be ridiculous.
given the TH400 i'm assuming this is going to be a drag car or street/strip car. given that bigass turbo and the associated lag (what A/R is it?) do you plan on using some kind of 2-step?
what are you doing for engine management? AEM EMS?
Janz99
234
Winnipeg, Manitoba
The turbine has a .96 housing on it. The car is being built for the street/strip, and i'll be using a direct port nitrous setup to spool it on the trans brake. Depending on how bad the lag is on the street, i might spray a small shot to get the turbo moving, then have it shut off. Car will be run off an aem.
Janz99
234
Winnipeg, Manitoba
^^^ Bingo... I machined my adjustable cam gears to accept magnets, then we;ll be using a hall sensor off the back cam gear cover. DaveH came up with this awhile back and it seems to be working very well for him.
Ryan
Clint
AzSupras
Apr 4, 2005
1,463
7
Mesa, Arizona, United States
Ryan
Very neat, What engine management system will you be using?
PureDrifter
VIP Cruisin'...
Aug 11, 2009
317
CA
www.clublexus.com
water injection?
a .96 ar will be laggy as all hell on the street, especially on an 88mm turbo. what kind of injectors/fuel system will you run? and when you say AEM do you mean EMS or FIC?
kikdurazz
what's the birdcage for?
winnipeg
It's nice seeing a local car get built properly. The previous owner to the car was douche (not Hams)
Can't wait to see this bad boy out next summer to get my doors blown off. :)
