if i were to pull the motor, drop the crank, throw in the one from the other motor, new bearings, arp rod bolts, replace the rods, clean it real nice, lap the head, new rear main seal, oil pan seal, check the water pump, then with the head replace the valve seals, valve job, and the N/A cams.
and then a metal head gasket, see if i can find arp studs for a dec price, maybe see if i can find some better valve springs and lifters( whatever is in the limited budget), and a new crank pulley as well as all around belt tensioners and check the other wheels and power steering pump.
with all that, because of the N/A cams changing the power band to more of a mid range rather than higher end, and the upgraded valve train as well as the lower end, i would be able to up the boost correct?
what can i boost up too??
i don't have the upgraded fuel pump yet, but i have 550 injectors.
so a new 255, what are my possibilitys with my ct26?
