7M+5M+6M+M3.....Confused??? :-)
Jens Lyn
95
Denmark
Hey all.
I just want to show some picture of my new engine that i am building this winter.
This is the description so far...
7mge 24V head.
5mge pistons modified for 24v head.
6mge short block.
Itb´s from BMW M3 3.2.
The engine will be mounted with new bearings, rings, metal head gasket, and new gaskets.
I have got 296 degrees cams for the project, and also i have to make 2 adjustable cam gears.
The exhaust header is fro OBX, and made of stainless steel.
Here is some pic...more to come.
The modified piston so i can raise the comp. ratio...
More will come later... :)
best regards Jens Pedersen
Jens Lyn
95
Denmark
I hope to get around 11:1 at compression rate, and a place between 250 and 280 hp in that engine.
I will build it as crazy and wild i can on the original parts.
then someday i will upgrade to 85mm custom made pistons and rods :).
Looking forward to hear this thing rev :)
Best regards Jens Pedersen
crisp
existentialincrementalist
May 25, 2007
1,785
Ohio
I can hear Handel's Chorus already!!!
HALLELUJAH!!!
...for those less cultured... that would be HOLY CHILD OF GOD!:aigo:
Or something like that!:biglaugh:
Truly epic! SUBSCRIBED!
What's your redline target?
-crisp
Jens Lyn
95
Denmark
The last engine i made with itb and original parts revs up to 8000 without any problems, and that is with hydraulic lifters.
This one her is with mechanical lifters so it is a little better , but stille the pistons and the rods are the weekest parts.
Jens Lyn
95
Denmark
The flywheel will be this one that i also made by my self :).
It is tested on my other engine and works very good !
Incl clutch the weight is 8.6 kg, and the original is 17kg :).
supraduper
126
merrimack nh
i always wanted to know if you could make a 32. bmw itb work... did you make your own flange?
what about sensors?
you gonna run on mge electronics?
pretty awesome man
crisp
May 25, 2007
1,785
Ohio
BlackDynamite;1428233 said:
I said the SAME thing!
...on another note... I just stole your sig quote...:biglaugh:
Carry on with this epic build!
-crisp
Supra_Villan
needs his car done
Nov 10, 2007
662
Wellsville MO
i love how you are using all original parts..i'm not an n/a guy myself but i can for sure admire one. I was always jealous of the other vehicles that could mis-match factory components for a better purpose (such as honda's and the 4cyl yota's) but my envy has been cured!
Jens Lyn
95
Denmark
what about sensors?
pretty awesome man
Yes i first made a drawing of the flange, and then had it made on a cnc machine.
The sensors is all from the Electromotive Tec3R, that i use.
It is very good :).
