Hey all.
I dont care that everebody is picking on me
I can handle it!
First of all.
The flywheel is tested at my other engine and works very fine.
The flywheel is made of a special type of steel that is used for that kind of things.
I work at a place where we build machines , as we also are building flywheels for so please trust me.....the biggest flywheel we are making is 1400mm in diameter!!
I know what i am doing!
The dyno numbers on my other thread is with the flywheel installed.
The clutch is a tilton clutch, not one i made by my self, and it is good for 950+nm.
There is a lot of rally cars and other hard used engines that are using this type of clutch.
The piston i use for this project will give the engine a HIGHER compression ratio.
If i do the plasticine test the 7m piston dry weight is 404g
Filled with plasticine to the top the weight is 422g
Difference 18g
The 5m piston is dry 363g
Filled with plasticine 374g
Difference 11g
So between 7m std piston and my custom made 5m piston there is a difference at 7g.
And then the dome at the 5m piston as i also found the weight of.
The value for that is 4g.
So 11g is the total difference.
1g is 0.001 kg.
I also did the test with water and 1g water is 1ccm.
So With the 5m piston i raise the compression with 11ccm.
It will be about 11.2 in compression!
The guy who helps me with this , has build many other engines like this.
Not toyota but opel!
He got his own firm and he is living of building race engines.
I do things many people only are talking about, and even some things that havent been said yet
I know that there is a big risk when i am re-designing the original parts, but i am willing to take that risk.
I will buy some custom made pistons one day, 85mm special build for this project, but i also want the rods to, so that is close to 5000usd just for that.
So i hope this engine can be able to run until i have collected 5000usd
Then it would be 3.2 24V
Thanks for all this critical conversation, i like to hear your oppinion for this project
At this pics you see 2 of my 3 little helpers he he he ....
They better learn from the beginning, what it is all about ;-)
Best regards Jens Pedersen
