drove it tonight guys....found out i have a broken heater control valve (gonna bypass temporarily) and a fuel trickle from using too big of a copper washer on my cold start injector. Upon first getting it started it would idle fine, but it would want to die really badly when i would hit the gas. So i was jiggling some wires and got no results. Then i moved my positive batt terminal (which i've discovered is too big for the post) and it would rev fine! so i took off for the first drive. Not very pleasant lol, it threw a code, it was very hesitant and then it died. The first time it died, it started back up, but then it died right as i was pulling back into the garage and wouldnt start, so i messed with the terminal some more and and fired up and went back to not being able to rev. So i'm going to fix the leaks tomorrow and get a new battery terminal. I had a chance to check the codes before resetting the battery and i got a 51 and an air temperature sensor(where is this located?) The 51 could be the fact that i have my air conditioning removed because i just calibrated the BRAND NEW tps. Base timing is set and i was going to get the timing light out and set the ignition timing but i didn't have a chance to do this. The oil pressure is good, vac is right at 18lbs, idle is a bit high about 1k-1300, no excessive smoke from the exhaust. Any input anyone? What about the wastegate issue? would that be a runnning problem? I have an safcII but its all zeroed out with nothing changed, 550's, lexus afm, 255lph pump 12v mod, afpr with fuel pressure at 44lbs vac line off, precision sc6152e 61mm turbo, 4'' intake, those are the only mods i can think of that might throw things out of whack. Thanks for lookin, tell me what you think, charles
ps i did do a vac leak test on the cold side of the ic piping and it held solid and had no audible leaks, i mean all vac hoses have been replaced with hose techniques kit so it shouldnt be an issue anyways. Also air and both fuel filters are BRAND new.
