what happend to the 85? and will he ever release the mods done to the car? besides the obvious ones? and also the 7m in that was in joels car that joel attempted to sell on ebay awhile back?
I know everything he did... I was there for most of it, and did some of the early wiring lol. RPS in the SFV did most of the turbo work, and V8 shop built the engine and the head work... I forgot the name though.williamb82 said:what happend to the 85? and will he ever release the mods done to the car? besides the obvious ones? and also the 7m in that was in joels car that joel attempted to sell on ebay awhile back?
bigaaron said:Cool, lots of good info so far!
How about a set of custom 5m cams with stock size valves and a mild port and polish?
hmmmm, I guess that makes it too complicated and expensive at that point to use the 5m head, since the 7m head can flow more then I need for the hp goal, and the Crower cams are almost ready now.
mattjk said:russ didnt start to make power until he put some huge valves in and ported the crap out of the head.
bigaaron said:6m is 3.0l with 2 valves per cyl right?
same stroke as 7m 91mm, 83mm piston, but older head.
How do I contact mr. "russ"? :biglaugh:
Or tell him about this thread, and tell him we want pics of the monster 5m!
yup. My firebird uses two valves per cylinder, and will make 400 hp. Thats n/a pwr also.bigaaron said:The valves are huge! Lots of V8 engines have 2 valves per cylinder and make huge hp, yes?
Tanya said:How about this HKS Mk2 eh? :evil2:
If you're talking about this HKS mk2
http://www.celicasupra.com/media86.htm
then blah, I say, BLAH! The bolt on kit kinda sucked, same with the Spearco
but todays technology is so much better than it was in 1986 and big HP 5Ms are totally doable.
Take a look at our top turbo'd timeslips and see what's #1
Turbo/Nitrous/Supercharger/V8 Drag Times
1.Jody Sille_____ <5MGT/M>(86) 10.669 @ 126.0 mphTimeslip
2.Damon Saul___<7MGT/M>(81) 12.225 @ 116.5 mphTimeslip
3.Donnie Spears_<6MGT/M>(85) 12.237 @ 112.6 mphTimeslip
4.Pituala_____<1JZGTE/M>(85) 12.685 @ 111.7 mphTimeslip
5.Jason Moorman<6MGT/M>(85) 12.862 @ 110.4 mphTimeslip
6.Joseph S______<7MGT/M>(82) 12.929 @ 109.2 mphTimeslip
7.David Shepherd<7MGT/M>(84) 13.148 @ 112.2 mphTimeslip
8.Eric H___n2o+<1UZFE/M>(82) 13.190 @ 109.06 mphTimeslip
9.Helmsman____<7MGT/M>(85) 13.445 @ 112.0 mphTimeslip
10.Swank______<7MGT/M>(86) 13.649@105.93 mphTimeslip
11.Racefiend_____<7MGT/M>(8?) 13.886 @ 102.5 mphTimeslip
12.Pewee_Cressida<1UZFE/M>(8?) 13.926 @ 101.46 mphTimeslip
13.John Nguyen__<1JZGT/M>(86) 14.014 @ 110.0 mphTimeslip
14.Mailbyte______<7MGT/M>(84) 14.621 @ 100.0 mphTimeslip
turbodhbar said:If you use the shorter stroke 5m crank you will have to have custom pistons or custom rods to make up 1/2 the difference in the stoke or you will have a real low compression ratio as the piston will not reach the top of the block.
QWIKSTRIKE said:No mention here of body weight or turbo used or Hp being made. Josh here in NewYork runs 10.0's @132mph all day in a 7m powered generation II body. Time slips really dont tell the story if the car is stock!
bigaaron said:Now bear in mind that the goal with this engine would be something like an "oldschool 1j". Not for drag racing and not for 700whp. A solid 425whp would be plenty. I want to stick to the M series, but also do something different that oldschool Toyota guys would trip out on.
supradan22 said:Wouldn't the 7m head bolt up to the 5m block that would be sweet and have a hybrid M-series motor.
