I got an Idea, 1JZ it revs high, it flows well and its a lot easier than this idea. I mean it sounds cool but I just don't think it would be worth the hassles in the end.
Wills7MGTE said:I got an Idea, 1JZ it revs high, it flows well and its a lot easier than this idea. I mean it sounds cool but I just don't think it would be worth the hassles in the end.
ma71supraturbo said:7m head on 5m block? That's basically the same as a 5M crank in a 7m... You just loose the oil squirters (if 7mgte) and you only have 1 knock sensor port tapped. Either way, you still need custom pistons and/or rods (5m pistons have 2 valve reliefs). Oh, and 5m/7m oil pumps are basically the same -- the main difference is the pickup location (front for 7m, middle for USDM 5m)
Honestly the easiest way is probably going to be 7m engine with 5m crank, 7m pistons, and custom rods. But this setup will be far enough off stock maps, you will definitely want to go standalone...
Doward said:Aaron, that's what I'd do - 5M crank into a later 7M ('89+) block.
The 5m is an 85mm stroke crank, right? vs 91mm on the 7M crank?
so it's a 6mm de-stroke, and you'll need to increase either rod length, or pin height by 3mm.
A 6.1" rod should do the trick, don't you think?
I know you can get LS1 rods that are 6.1" Hell, Scat's got a set of 8 forged 4340 I beams on Summit for $245.
I retract my machining thoughts here! Call up Scat or Eagle, or whomever - you should have no problem getting a 6.1" rod with the big end, piston pin, and width needed!
What is our rod width, on the big end, anyway? I like this idea. Do a 2mm bore on the block, and have an 85x85 square bore setup. Oh snap, that's awfully close to another engine I can think of![]()
suprarich said:Why all the talk of custom rods? I will ask again what has the stock 5m rods been proven to? Because to destroke the 7m with a 5m crank you just use the 5m rods also. 7m pistons go right on the 5m rods too.
No way! He should put it in his Ford Ranger.cnewingham said:crazy idea Aaron but I love it! you gonna retire your 7m then?
Either that or the deck height of the 7M is taller in which case you would want to keep the 5M shortblock with a 7M head to avoid custom rods. One way or the other should work.suprarich said:Why all the talk of custom rods? I will ask again what has the stock 5m rods been proven to? Because to destroke the 7m with a 5m crank you just use the 5m rods also. 7m pistons go right on the 5m rods too.
