2JZ NA-T in my 87T
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I was just thinking I might update this thread!
No new dyno numbers yet, but soon!
Best dyno numbers to date were 573whp, 592tq.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Here are a bunch of pics I've taken in the past 3 months which I haven't posted because the thread seemed to die.
More recently..
Blitz Power Meter came so I can boost by gear
I also got cams
Cobra wheels with Mickey Thompson ET Street's
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I'll post specs of the cams later tonight...
I'm trying to decide if I can get away with this bad boy... 2JZGE-T HP record on stock internals.. anyone? :aigo:
dok33
My fuel pump precedes me
Apr 16, 2005
934
Austin, TX
DO EET!!! Try to max out the MP T70 first so I know what the limit is :) I'm stopping at 540 ft-lbs either way because that's the limit of my clutch, I don't have the fundage to buy a baller clutch like you ;)
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I think the stock bottom end will do 850+, that being said this turbo is up for sale as it is FAR too large for my HP goals. LOL!
I'm looking for a non-massive GT42. This one has an 88mm inducer and 117.x exducer.
I haven't read all of this thread, so I ask this at risk of sonding incredibly stupid...........Is that a meth injection kit installed? Is that a tank in the back for the washer fluid? Is it set up through your standalone, and if so, how hard was that to do? I've been thinking seriously about a meth injection kit for my 1.5jz once I get it installed and broke in properly. thanks.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
not a stupid question at all. I run methanol daily. The tank in the back is from a volvo and it is for the methanol injection. I actually used to run windshield washer fluid, but now I use straight methanol (from a go-kart shop). I set it up throught the stinger w/ an auxilary output. When the manifold sees 18 PSI it cuts the pump on through a relay. From there I just tuned the car like it was gasoline (it will lower your duty cycles by about 15%).
I love meth injection I definately recommend it. People argue about the effectiveness of 100% meth vs a 50/50 mix, but I figure the more octane the better.
When considering methanol injection keep in mind that most systems run without a fail safe, so if something goes wrong, it really goes wrong..
I would only want to run it to lower the temperatures a little. I don't want to run more than 18-19 psi. It looks like something I'm definately going to check into and knowing you've got yours set up through the stinger makes me want it even more. Thanks.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I pay $7 per gallon. I know I could get it for cheaper but I don't drive my car that much and it's really convenient.. much better than paying $15 per gallon at home depot for denatured alcohol.
csnow
Matthew 6:33
Palm Bay, FL
Wow, $7 bucks isnt that bad. What psi are you running on the meth? Also, when do you have the meth start spraying? I would assume progressively from 11-15 psi upward.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
tissimo;1008202 said:
what meth system do you have?
Devils own
The meth comes on at 18 PSI. I know it's a little high, but so far it works too well to change it. Maybe when I install and re-tune for cams..
It's not progressive. Progressive would be best. I was actually surprised how easily the setup tunes even tho it's on/off. My AFR's stay exactly where they need to be during the changeover.
