Actually, the 'sweet spot' on that 67mm turbo, is at low boost. Look at our motor, pushing 12 psi. It's right on the edge of that 76% efficiency line
The thing of it is that you can push more pressure than most turbos, and do so without heating the intake charge excessively.
Personally, on a 7M running 7500rpm, I would run no more than 26psi (that is on the 70% efficiency line) maximum from the turbocharger.
Daily I would run 18psi running 7200rpm (and sit happily at that 74% efficiency island).
Actually, that's exactly what I'm going to run on my setup, LOL
Wastegate = 12-14psi
Daily Driven = 18psi pump gas tune (with cams/ported head)
Race Only (and dyno run) = 26psi + 50 shot of nitrous (this will not be until after I have determined the maximum fuel flow available from my 680ccs - I'll most likely need 750+cc injectors with an external pump at that level)
If you want an idea of the power levels that will be, moreboost.org shows -
521rwhp @ 17psi (.68 A/R P trim)
521rwhp @ 18psi (.68 A/R P trim)
533rwhp @ 18psi (.68 A/R GTQ trim)
635rwhp @ 25.5psi (.68 A/R P trim)
I'm going to be running a .68 A/R P trim PT67 myself - I may swap out for Chris' .81 A/R housing, though - we'll see
I fully expect 500 daily driven rear wheel hp - This is a good, safe tune, that I will have no problem running all the time.
I fully expect 675+ race mode rear wheel hp - This will simply add more fuel, as well as the nitrous to supercool the intake temps, and bring the timing back down as well.
I fully expect to hit my goal of 375hp from my build :naughty:
I full expect to be faster than Jeff, at least. :biglaugh:
