Gixxer: You could argue that, yes - but the intercooler should really flow well enough to not be a larger restriction, and be efficient enough to remove a lot of the heat from the air in that single pass.
Otherwise, you need a better intercooler! Remember, if the air velocity slows down, it could get 'backed up' and that would decrease the overall efficiency of the system.
Figgie: That is exactly right! Just remember that our parameters are slightly different - we can go UP TO ~300mph before that flow difference actually becomes noticeable. A pipe flowing 30lbs/min @ 290mph vs a pipe flowing 30lbs/min @ 100mph - you will still flow 30lbs/min. Now, a pipe attempting to flow 30lbs/min @ 400mph, will NO LONGER be flowing 30lbs/min - the boundary shear will now become a restriction to the flow, so you would expect to see a maximum of around 26lbs/min (guessing at this one) @ 400 mph. The turbulence would disrupt your flow.
