tekdeus;1251720 said:That test was on a stock NA 2JZGE but with cams. 310 Torque at 3000 rpm, 520 tq at 4000. Imagine a stroker 3.4L TT 2J... Incredible!
That's definately a 2JZGTE head, must be a 2JZGE bottom end.
grimreaper;1252256 said:i just want to hear the turbos sing!!!
gnarkill87;1252015 said:Its about time someone does this on a supra! My buddy has a compound set up on his tacoma a gt30 and a gt45, hes using the stock 3rz (2.7L) too. before he turned the boost down for daily driving he was seeing 30psi at around 3200-3400rpms!
figgie;1252367 said:just because you compound the turbos does not mean they become more efficent.
A gt35r on a 2.7L car. I doubt that he acheived even 15 psi by that RPM.
Again,
physics is infallible. That means that this setup does not throw physics out the door and make it work better.
ENTROPY.
Learn it. Accept it.
gnarkill87;1252402 said:Hate to burst your bubble but he Was making 30psi before 3500rpms.
Evilempire1.3JZ-GTE;1252457 said:Why compound turbos though when you could kick out 1 of the turbos and use a supercharger!
1 supercharger induces torque & power in the lower rpms then turns off via a magnet clutch like the ones on an A/C pully.
Then have only the large turbo run when the rpms or load is at a certain stage where the supercharger would choke!
No surprise there twin charging have been around also for a while also and they get better results with a little bit less plumbing because the supercharger doesnt run off exhaust plumbing figure that out.
