MKIII-DRIFTKING said:
MKIII-DRIFTKING said:Jaguar - Tack cloth? I don't like the sound of that either.
Jaguar_5 said:Have you ever used a tack cloth? You get them from painting supply stores, you can use them for removing any dust or lint before a paint job, and inbetween coats, i think they even have special ones for removing nibs or contaminants off of wet paint
I can't think of any possible way it'll damage a fully cured paint job! They aren't very sticky![]()
johnathan1 said:Maybe if you pat the surface with the cloth...but the correct way to use it is to wipe lightly. Go watch the videos on Dupli-color's website.
MKIII-DRIFTKING said:Here you go...for the impatient fellas on SM! :biglaugh:
All the wiring is back in. Heavy! I can't even push the car anymore :biglaugh: oh wait, that's because of the flat tire.
Steering rack w/ wheel and all that is back in...Heavy! I should've weighted it. Has to be at least 50lbs. But I do like the telescoping and all that.
All the moldings are in...Heavy! Each molding has to weight at least 10lbs. J/K :biglaugh: no chrome strip yet.
Here's what I did yesterday...
Today I'm hoping to finish the rear and install the rear bumper. I'm thinking of trimming down the rear bumper support. That sucker weights about 37lbs if I recall correctly. I wish they were aluminum.
