f00g00;1959367 said:The 7M fan blades don't fit the 2J fan clutches. The fan mount diameter is over an inch larger on the 2J fan clutch so the hole is to large for the 7M fan to fit around, unless there is an aftermarket clutch with a smaller fan mount diameter for the 2j.
ians13;1959489 said:look at the first pic i posted. it's a 2jzgte fan clutch with 7mge fan blade. the clutch is aftermarket from advanced auto parts.
ians13;1959333 said:old thread, but my setup my help some people.
2jzgte fan clutch with 7mGE or GTE fan blades.
check out the pictures i have no issues with this setup no noise or vibrations.
f00g00;1959385 said:You can get more silicone from the dealer by the ounce, open the fan clutch and squeeze the bottle in. I have 3 extra bottles in mine and my car still overheats when I use the a/c.
mjsn1;1959374 said:PIC of clearance between fan and rad please.
also what do you mean by heavier weight fluid for the clutch?
hvyman;1959703 said:Hard to get a picture with the shroud on. But i have about 2 inches between the fan blade and the stock radiator core.
scottiedawg66;1976493 said:What radiator and shroud are you running?
