Picking the final six. Only the lightest ones can play...DEFIANT 7M said:Going with stock rods. Putting in the ARP goodies and checking bolt(stud) stretch.
cuel;893165 said:Well, I just read this whole thread again. Wow. I am, quite thoroughly, impressed. Glad to see you back on top now, and that you're close to done. Apparently, very close
By the way, would be interested in more detail about how using the old head for a bore plate worked out...
Setheroo;893260 said:Welcome back, I think I speak for all of us when I say... I can't wait to see the end result.
I need some NA inspiration!
MrWOT;893678 said:Just curious, but have you considered running a dry deck?
AF1JZ;893697 said:Where's the videos??? I've been dying to see this engine rev for some time now. Congrats on getting it running though.
suprarx7nut;893744 said:I read all 38 pages and I can't wait to see the final or even updated product. This is one of two builds I'll be watching like a hawk.
Hey thanks, it's been a long time. I have a hard time driving other Supras since mine has been down.
gnarkill87;894236 said:i think the only way this build could be anybetter is if you went alcohaul instead of gas!:evil2: but man props for doing this this thing will be well sick:aigo: and thats even an understatment.
:biglaugh: I am going alcohol...later! It is one of those rooms of improvement:naughty:
The bottom end was a challenge. We clearance what we thought was enough to find out it wasn't. The crank scrapper and girdle combo need a little modn' to get it to work. We used 7M head studs for main studs because the girdle is really thick! The wrist pins where cut wrong so we had to send them back and get them recut (two years later!!:biglaughThe dry sump pan would not fit with the girdle! This is just the bottom end....My head is just as crazy, with 2JZ shim/buckets, and 2JZ valves. Here are some old pics of the clearancing of the block that was not enough for the stroke!
Ma70.Ent;895545 said:Can't wait to see this up. I want to see the potential of our GE motors and I want to see which modifications you have done give the most gains without breaking the bank completely.
Ma70.Ent;895612 said:Hey Allan, would you like me to clean this thread up so it's easier to view for others?
BTW, you have a PM![]()
IJ.;20048 said:Allan: Ever thought of getting a shorter timing belt and get rid of it altogether?
I did this with a 2 litre Astron I built for the balance shafts just had to plug the oil holes.
(Looks brilliant so far can't wait to hear it run)
Ma70.Ent;895686 said:Ok, done. I just cleaned out a shitload of posts (over 100 easily)
I deleted all posts that had something along the lines of "i want pics" "good work" and "keep it up". I tried to keep the questions so that people wondering about this good read them and have them answered.
DEFIANT 7M;4772 said:I've done a lot of things with this engine I really didn't understand, until sometime later. This is one of those things.
We machined the shim bucket (some call them lifters) bores to accept the 2000 and up Toyota Echo shimless bucket. Why??? The cams have such a radical lift they will "spit" the shims out. Or knock them right off the top of the buckets. Machined the bores? The stock 7M buckets are 28mm in diameter, the Echo buckets are 32mm. The cost is about $12.00 per bucket and they come in a range of sizes too match cam lash. I got lucky and had a 2JZ N/A given to me that thru a rod. We stripped the engine and Daryle walks over to my 7M head and says look these buckets fit! Well that was money saved to say the least. At the time the main concern was stoping the "shim spit" problem. Daryle said there was another plus to this mod. It follows the mod many BB Chevy guys do. By enlarging the lifter bore size using BB Chrysler lifters in BB Chevys. The larger bore will change the ramp rates, overall cam duration, and maximum lift numbers. Which will change the dynamics of my cams...too the goodI was wondering why he had me get the cams I did, know I understand. I will pick up more duration @ say .020 vs a cam of a similar spec @ .050. Not to mention the increase in lift. I guess you can say the cams will have more leverage to open the valves quicker and a bit longer. Here are a few pics of the Echo buckets.
http://www.villagephotos.com/pubbrowse.asp?folder_id=630110
MrWOT;895857 said:So did you weld up the head and shape it? Or still trying to work with the stock ports and chambers? Looks like someone took a spoon to the bottom end. Don't mean to be a "asking for pics guy" but I want to see the head and pistons too![]()
