101MM Stroke 7MGE
DEFIANT 7M
101MM stroke of INSANITY!
Nashville/Miami
MrWOT;896002 said:
2618 eh, probably a good idea for that kind of compression. I am a little surprised at a few things, who designed them? I'd really like to take a look at the ports and a better look at the throat area but I understand why, looks like the valve guides were ground all the way to the port roof? Can't wait to see it run :D
The head was sent to Diamond. They digitized each chamber and then collaborated with my builder to make pistons a that would suit my application (high comp/nitrous). Yes the guides are ground to the port roof. The pics are the very first and only pics! There has been major changes let me say that.
DEFIANT 7M
Nashville/Miami
Got my rear tires and front wheels today:love: I have a pic of the front and rear tires side by side also.
Figit090
Fastest mk3 GT4 1/4 mile!
Jan 7, 2006
1,835
Humboldt County
DEFIANT 7M;895549 said:
This has to be my favorite pic! What does a stock piston/rod with a 101mm stroke look like @ TDC?:biglaugh:
HOLY CRAP!! I never knew how much different this was...if i did, i forgot! I didnt know what stock was, now i do! amazing..
that's a bore plate? I'm imagining you made a thick plate for the head to sit on? totally newb guess there... but i can't think of any other way for that kind of stroke clearing the head. if i'm right, do you have to use two headgaskets now?
awesome work bud i can't wait to see videos and such! nice rim choice too! you fronts are bigger than all my tires :( lol.
i forgot, do you have a HP estimate on this build?
gofastgeorge
944
Texas
Well, I made it through this whole thread........
Can you get more of the flanges to do the RB throttle conversion?
Can you get them out of aluminum, say .375"-.500" thick ?
I have the RB throttles, and would love to do this.
What did the dry sump pan cost you ?
Also,
You may want to re-think running the cut-off oil pump drive shaft.
The timing belt induces a considerable amount of side load on that pulley/shaft.
Without the rear bearing to hold the shaft in alienment, it will cock the shaft off to one side at an angle.
I doubt if the plain bearing will survive very long.
I would guess just minutes.....
Just a thought......
Cool build !
DEFIANT 7M
Nashville/Miami
madsupra88;897137 said:
so you have A big lift cam?? what kinda of lift
Yes...(.450)
Thanks man...:icon_bigg The bore plate is only used for machining only. Oh I got you...No the pic is a stock piston and rod on the stroker crank. My pistons have a different wrist pin height. Which makes them drop to factory deck height.
Also,
Cool build !
I may be able to. I got everything from Arnout..he may get on from time to time. He is in Finland. I am working trying to have a casting made. My pan was $250 or so if I remember right. We plan on using a shorter timing belt that would eliminate the oil pump drive shaft all together.
DEFIANT 7M
Nashville/Miami
See the difference in the piston pin height.
The goal is three hundred......shop talk is 385-420ish without the nitrous.
DEFIANT 7M
Nashville/Miami
madsupra88;897357 said:
did you have to clearance the head alot ? u think i can get away with .400 without clearancing ?
I decieded to use the small cams first. But I will have to clearance the head for my big cams. I doubt you can get away without clearancing.
DEFIANT 7M
Nashville/Miami
Some shinny stuff.
Figit090
Jan 7, 2006
1,835
Humboldt County
ahh, i seee. thanks. I thought that 'test fit' was the actual setup and i was like...what the hell? :aigo: lol.
I wonder if it would work to have a plate to raise the head off the block, with a plate and two gaskets, or one thick gasket, a few cm's thick... :p
OMG nice shiny stuff! your engine is going to be the best GE ever!! how pricey is that plating?
DEFIANT 7M
Nashville/Miami
Actually some high comp big stroke Hondas due weld a plate to the deck!
http://www.team-integra.net/sections/articles/showarticle.asp?ArticleID=20
MrWOT
NERD
May 9, 2007
57
Grass Valley, CA
Yeah, no getting around the piston outrunning the flame with a low R/S at high rpm. Usually they are brazed, and as long as you can source the correct sleeves and custom rods, and have the hood space, it's great for race engines. I've seen folks hit 2:1 with a good deck plate :evil2:
Figit090
Jan 7, 2006
1,835
Humboldt County
thats interesting...lol.
what goes in the deck plate though? i mean, those aren't cylinder walls because there is no water jacket, soo...uh. thats weird. maybe a set of sleeves that goes down in the welded-on deckplate? more views would help but i dont want to get too off-topic.
cuel
1,536
Baytown, Texas
Do your pistons have 3 compression rings? Might just be the pics., but it looks like there's three grooves for comp. rings, and one oil ring groove. Curious, as I haven't seen a piston with a ring set-up like that before.
