Man I'm out of breath running around the house screaming!!!!!!!! I knew it was possible:biglaugh: God its been sooo long if I remember right you have the Flatlander kit and 12:5, cams. I can't think.... Did you dyno with the nitrous too? Your pressure plate may be too "heavy". A lot of the DSM guys develop crank walk from the plate hammering. Well that's what I've been told on more than one occasion. I gotta dig up specs on your set up. Man dust it off and get her running again:bigthumb: I knew you would hit it before me!!:biglaugh: Guys Bugwugger and I were the only crazies years ago, he started his before me. My quest to do everything possible and impossible has me still building:biglaugh: But not giving up especially now. Bugwugger post what you have done so everybody can see it is possible to make NA power:bigthumb:Bugwugger;1796692 said:I made 303hp with 336t. Looking to get this thing running in the spring. I was using the CenterForce Dual Friction. Was having problems starting the car, figured it was the starter. After removing the starter and looking closer... I could move the crank from the dampener forward and back at leat 1/2 in. I removed the flywheel and saw that the wheel had been rubbing the rear main area. Car has been sitting for 3 years now and have not touched it. I am going to work on her come spring. any ideas or comments????
