1000hp 7MGTE
Status
Not open for further replies.
IMHO the reason the MKIV's run faster in the 1/4 than us is the simple fact that they can get more tire in back...
That and they seem to have LOTS of practice :D
quake
toyota tech
Apr 13, 2005
619
r.i.
guys the 2j is a great engine but the 7m will do better at the same level. Most mkiii guys are cheap and it shows when we do mods and post videos. Most are kids and don't follow all the proper steps, and thus the community suffers. The 7m has the longer stroke thus we make better tq and this counts on the street. Next mod after making good power is tires... Wayy back i worked at a tire store and we had tons of low pro's in stock. I tested lots of new tires back to back on my turbo maxima fwd- this car could smoke the tires at 80mph. Lost alot of races due to traction. Ended up using toyo and nitto tires and playing with alignment specs, finally getting the car to hook.
Next i picked up my supra and a this was because i wanted a rwd car as all my v-8 buddys seemed to have no problem hooking on the street. To date i have not even touched my suspension just a set of tokico's and eibach springs with toyo t1r 275 35 18's and i can go full throttle in first with no tire spin at 480rwhp on the street.
1000rwhp is not really a big deal just takes time and money, but you will kill yourself on the street. You have to build up slowly and get used to the power along the way or it is just talk. Do you think you could take the keys to Duane's car and go for a spin at full throttle?... think again if you are making 300hp and have never driven anything like that before:nono:
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
7m can make 1000, as Rich said, it already has made that (and more) in Gary's dragster.
In reference to the 2j, the 7m will NEVER have the power potential of a proper 2j. This is not debatable. Limited bore = limited valve size = ultimately limited flow. You can port the head as much as you want, but eventually its like shoving 10lbs of shit into a 5lb bag.
That being said, the 7m can still reliably make much more than you need when built/tuned/maintained properly. Its all about spending the $$ in the right places....
quake
toyota tech
Apr 13, 2005
619
r.i.
power potential no, but i would still take the 7m over the 2j at the same rwhp level because of the tq. The 2j starts out better because it is a better design as it came out later in production.
8,898
Poodles;1217497 said:
Last I knew the record for a stock 2J longblock was 800... Stock 7M was over 700, so it's not far behind.
Mark Tozer said his went 30,000 miles before dying at 980 rwhp.
Slow66
Apr 3, 2005
1,457
Newington, CT
Dont have to tell me that...:) Im one of the ones on here in the process of building a 1200+ hp 7m :D
If i wanted to build a 2j i would have...
Talking about torque... the stroker kits for the 2J are abundant now, so the playing feild is level.
Stroker 2J is a monster...
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
Well the average price is about $2000-ish. So, $2000 head start.
These are used motors average off Ebay.
And if had to start from scratch I'd be a fool not to go the 2jz route. Well, If I planned to make good stress free power, anyway.
But for now I have my 7m and if blow it up most likely put it all back together again cause I never take no for an answer LOL.
PS: I also like the sound of 7m over the 2jz - the 1jz is a close second.
rakkasan;1218219 said:
Fine, tell me the cost difference between a stock 2jz and a stock 7M motor. I'll bet I can mod a 7M to be BETTER than the 2J for the difference in cost.
MRSUPRA
838
Maryland
Its funny hearing these debates about weather a motor like the 7M can make 1000rwhp. Of course it can. The weakest links will need to be upgraded. But the basic design is there-strong iron block and a forged crank.
And as for comparing the 2JZ; Saying that it's so much easier because of the better head flow is kind of funny too. Anyone who knows anything about turbocharging, should know by now that you can make the most inefficiant motor produce huge power with a Giant turbo and a crazy amount of boost. That's how the 2JZ'z do it- which are not nearly as efficient as many honda, nissan and Mitsubishi motors.
Global688
17
Renton
I dont know about the rest of you but I live up here in Seattle where its wet out. I have issues with decent tires and bolt ons on a stock motor. (which is fast enough imo) Give me a 1000hp and I wont go anywhere.
quake
toyota tech
Apr 13, 2005
619
r.i.
:biglaugh:
ZFast300Z
Trouble
Dec 15, 2007
102
Wisconsin
You think the a70 crowd is bad. Hang out on some Z31 forums. Most dont have the budget for a 300hp build, and that only requires a 3" turbo-back, intercooler (we didnt get one stock), and a boost controller.
Electramotive made around 1000 horsepower on the stock crank before upgrading it for endurance racing. The big problem is the single cam VG heads. Nismo used a completely different head casting for the VG race cars.
I would much rather start a 1000HP build with a 7m then a VG30E.
sthmstr
219
Colorado
I hear those are a major pain to work on(not as bad as the Z32 though). Kudos to you for rockin such a rarely modified car!
Adjuster
Supracentral;1217206 said:
True. And most 2JZ powered cars are damned near undriveable in that condition as well. By the time you get the headwork, cams, turbo & clutch to generate and hold all that power, it's certainly not "streetable". You can drive it on the street, but as I said earlier it's not fun.
And you had better hope you never get stuck in bumper to bumper...
No joke on this one. I just barely got mine running again, and I'd forgotten how much I hate using the clutch on this beasty. (Sprung hub, but it's still an off/on switch, not much slip at all, and it's noisy, and rough, and completely uncivilized around town.. )
But I suppose that's the trade off. (Or I can buy a carbon/carbon clutch, and possibly get a smoother engagement that will hold up over time.)
I doubt very much that is going to happen however. (Spending more money on this car is not an option right now. Selling it however might be.)
The RS6 calls to me every time I drive.. Power and refinement in one sedan package that screams sleeper to anyone who does not know what they are dealing with. :) Add in a few mods, and 550awhp is very possible. So are mid 4 second 0-60 times.
Then again, I must be getting old.. the ride and comfort of the A8 with only 300hp is relaxing after a cruise around in the Supra. :)
Too many toys.. LOL
Status
