Why is the 2jzgte so much better?
charlesshen
256
orlando
suprahabsfan;1000835 said:
Maybe somebody can answer this for me. I always think about this.... why are there 1500hp 2jzgte's and the highest i've seen a 7mgte is 1000hp or so, in that dragster? What could make up for that 500hp diference? Is it the head? If so why can't we port it to match the flow of the head? Is it the rotational assembly? If so why can't we make that much power with eagle rods/crank/pistons etc? Is it the variable valve timing? Again we could just buy different cam shafts. What about ffic? We can do that. ECU...we can get AEM EMS... CAN SOMEONE TELL ME! I can't figure it out!!
1j and 2j are made out of slightly different metals then the 7m
Larger bore diameter removes the Valve size restriction
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Because the 2jz is gods balls. Its also a much better engineered motor. It also probably has less miles and has usually been kept better due to the price range of the car that it is in.
miekedmr
mkiii in hibernation
Jul 12, 2005
513
Upstate NY
HommerSimpson;1000945 said:
Ok so the 2J is a much more advanced engine.. will it run all day every day at 800hp ? for 100k miles ?
The issue is not how much power it's capable of making, it's how much you beat on it.
If you want to actually PUT DOWN a regular 800hp every day, you need a train engine or something similarly large and durable.
A 1200hp engine might be able to last 100k miles if theres a grandmother driving it around. After a track day at that power level, though, any normal car engines are going to wear pretty badly...
Believe it or not, most supercars like ferraris etc don't actually last that long mileage-wise. Not without rebuilds and a lot of money.
OneJoeZee
Retired Post Whore
aboard the Argama
My 1J block and all internals were cast from Adamantium. I tried to rev it to 40k running 30psi on 87 octane with a CR of 14:1 and I still couldn't break it.
I dunno what kinda engines you guys got.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
so thats what killed wolverine :biglaugh:
HommerSimpson
1,067
New Smyrna Beach Florida
Well im talking a daily driver that if you needed to with push of a button could lay down 800 hp... but other wise have tuned for street...but yes get on it now and then .. as for instance im supra is my dd...and i drive 44miles round trip just to work on pretty much strait open road...
Now just what does it take to make a 2J put down say 800 hp and be reliable and a good DD...After what IJ said .. im going to re rebuild this new pistons bore it crank ground and rods redone... then im gona save for 2J no if ands or butts about it... :}
O and im going to put the fucking rods in right this time.....
miekedmr makes a good point as most of the failures I've had in the past 6 years have been in trying to get the reliability/longevity I desire at my Hp level and to suit my driving style/car use.
Every single time I drive my car it will see a full boost pull to redline at least one (when it's running correctly that is)
In the past this was often 8300 rpm and 30 Psi and parts do fail.
I also will drive the car a 1000 Km's a day on the weekends so it needs to be reliable.
For me the cutoff point seems to be around the 500rwhp mark, I know there are a lot of guys making much more Hp but I also think if driven like my car they'd suffer the same failures as I did.
There has been no expense spared in my motor and it's been carefully assembled each time.
tissimo
Stock is boring :(
Melbourne, FL
Poodles;1000893 said:
Because the 2J is more of a square engine (stroke/bore) while the 7M is a longer stroke than bore. They can get stroker kits that increase their displacement quite a bit while we don't have that much room for one.
All the 1000HP+ 2J's I've seen are running the strokers these days. Also keep in mind they spin these handbuilt engines up to over 8K RPM, if you know anything about the relationship between horsepower and torque you'd know why that's important.
Also keep in mind you have a more modern engine design in the 2J...
thats the biggest thing right there, the ability to rev. 8k on a stock bottom isn't uncommon, and 9000+ on a built engine with headwork isn't crazy. When you have a big ass turbo that doesn't go fulltilt till 5500+ you want to have more then 7000-7500 (of a built 7m's) head room...
tissimo
Stock is boring :(
Melbourne, FL
but you did blow a 1j :sarcasm:
TurboWarrior
Canada
ive been stomping on my 7m for years now and have never had a problem as a result. whats your point joe? Ive never experienced rod knock either in all the years ive owned supras.
The only thing that makes it less reliabile in my opinion the age of these cars.
I love both engines, Hearing a mkiii or mkiv roaring past me always gives me a rush. Id like to own both gens one day i don't have a favourite.
Ok so the 2J is a much more advanced engine.. will it run all day every day at 800hp ? for 100k miles ? as a DD that you beat to death everyday ? or is 800hp to much.. i know you cant drive a 1000-1500 hp car around as a DD and excpect to hop in and drive 1000miles on spur of moment and not worry your ass off...
whats the limet of a DD hp ... Opinuns ?
There are some 1000hp DD's but then again think about one of the variables mentioned earlier...money.
You can not have more than 2 of these 3 at any time...
FAST
CHEAP
RELIABLE
But then again all of these are also opinions inwhich means they can all be taken in differently. An SRT4 is fast to an average non turbo neon guy. An Evo is expensive to the average NA Eclipse guy and a Honda is reliable to the average MK3 guy.
It all depends on where you stand in the crowd and on the payroll that decides how you feel on these.
Also
I have an issue of Sport Compact Car with 4 crazy hp Supras(mkiv's) but I'm not sure which issue:
One was a 1000hp with stock brakes.
One was a +1000hp DD with over 100K miles on it.
One was an +1300hp that ran 8.2 second.
One was a 800hp DD built by the same guy that built 2 of the other 3
HommerSimpson
1,067
FAST
CHEAP
RELIABLE
Also
well 800hp is number im talking about.. how hard is it to get 800hp out of a
2J ?and be DD
tlo86
Jul 24, 2005
3,914
Colorado
IJ.;1001130 said:
I've NEVER met Joe so that never happened!! :aigo:
ROFL!!
charlesshen;1001092 said:
about the metal ya i forgot what it is they used in the metal but it helped fix the bhg problem along with metal head gaskets look in to it
yeah IJ do some research for once! :biglaugh::biglaugh::biglaugh::biglaugh::biglaugh:
