PICS ADDED AT PAGE 14
1. A used 2JZ is more durable/reliable.
2. A used 2JZGE can be sourced very easily for 400 bucks or less. You can re-use the head/rod/cap bolts. 300 for a thick HG and other assorted gaskets. Dont tell me you can build a comprable 7M for that price.
3. Im sick of scored camshafts.
4. Piggyback computers always have some quirk to work with or re-program. Going with a 2JZGE(T) and AEM keeps it under $2k.
5. I am sick of rodknock. Dont tell me its my fault.
6. The bottom end of a 2JZ is designed/built better than a 7M.
7. The stock valves are 1.5mm larger in a 2JZ. Oversize valves in a 7m still wont flow as well.
8. A 2jz wraps to higher RPMs.
