Where does this go!
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
HellsLegion said:
Ive got lots of tools. Lemme know what you need. Also, 5pm is when its bad here. lol.
If I can brave the ride to Hayward ill come.
But Hey.... Dinner =P
Ill prolly come with it unplugged as Johnathan said
YOu drive it dude. Its won't be a problem. Stop being a chicken...its not like its overheating or something.
Remember I have a Cressida so I can try the tps of it too.
chriso
Supranian
Bay Area, CA
Kyle,
Tomorrow night I can come down after work if you like. LMK asap since I have to load the car with tools and such in case we have to operate. I can bring a spare TPS (turbo only) just in case it MAY work????? I don't have an NA one right now.
chriso
Supranian
Bay Area, CA
johnathan1 said:
I think the Turbo one will work on the NA, you just have to flip it around 180 degrees...someone correct me if I am wrong.
I do know that the Turbos are facing the other direction but don't know if they are the same TPS or not??? I also think that pre-89 and 89+ are slightly different but I don't know how different if at all (does that make sense???)
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
Chris, Today Im going to moes around 2. Ill give you a call later.
Only Jenny can call me Squarebuts.
BTW Jeff said that all TPS's will work NA wise, aside from the first few months of an 86.5
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
If that code 41 is the one for the idle circuit, it will set that code if you touch the peddle, throttle, or disconnect tps while the test connector is jumped. Like weez says, spray around everything that might have a vacuum leak with carb cleaner, it will rev higher when it sucks it in, and look at the throttle plate , make sure it is closed completely, not hung up for some reason.
suprastanger507mgte
Hayward , Ca
Kyle cannot work on his car btw. He brought along his little sister to work on it ...lol...
It appears it was his TPS..I put the Cressida one on, but the numbers are bit different so he needs to get the real deal , NA shiznit.....
Squarebutt.....
