Whats YOUR special trick for getting into reverse?
Status
Not open for further replies.
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
-Usually- straight into reverse works. If it's sticky, I drop it into 2nd real quick and then it slides right into reverse like a cheap porno flick.
GotTurbos?
2J = Here; Swap = Near
Apr 24, 2006
951
Dallas, TX
I don't really care if technically it doesn't help. Its as simple as this:
neutral-reverse hardly ever works first try for me
neutral-reverse-neutral-(clutch out, in)- reverse will work like half the time
What I do works every time for me.
You can throw transmission tech at this thread all you want but that doesn't change the fact that my R154 doesn't give a shit.
87mgte
87 Turbo Targa
Sep 9, 2007
536
Sequim
AGlobalThreat said:
Reverse has no synchros iirc, so to correctly put it in reverse you need to first put it in one of the forward gears.
I push in the clutch, go 1st, then reverse. If it doesn't go in, release the clutch and press it in again, go 1st and reverse again OR sometimes 1st-3rd-reverse works for me too.
I'll have to try that Gotturbos, thx for the tip
i'm with globalthreat. i just go to reverse and if it doesn't work the first time [and it doesn't usually since my clutch is shot to hell], i just go to first and it goes right in.
Ckanderson
2,644
The beach
Big Wang Bandit said:
My car is an auto, my mom's isn't my friends aren't.
Oh and for me, Reverse is D-N-R
thats vierd!
I dont know what mine is... i havent driven it enough to know... :cry:
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
i got that down on ever tranny
frist to revers if that don't work
frist let out the clutch peadle a tad to the point were your car want's to move then off to revers click
works on all cars never lets a me down EVER
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
BlackMKIII said:
Clutch in, into reverse. works right 90 % of the time.
Otherwise:
Clutch in, doesn't go. Put in neutral, release clutch. Clutch in, try again.
Works like a charm every time. Just the occasional *CRUNCH* that can be embarrassing.
Which is exactly why I put it in one of the forward gears first, it doesn't make that noise and slips right in.
I tried just the clutch and neutral today and it made the *CRUNCH* both times.
to stop the CRUNCH, push the clutch in, wait two seconds, then try reverse. The crunch is from the gearsets still spinning.
I never have an issue, and now that this thread popped up I tried to figure out exactly what causes it... A good delay between pushing the clutch in and then going for reverse helps a lot I've found, not to mention I didn't have ANY issues today after figuring that out.
I know, I've got too much time on my hands, but I wanted to understand the issue more. If you're at the gate for reverse and then push the clutch in while pulling it will grind, clunk, and fight you. Relax... Stay in neutral, clutch in, count to two, go to reverse, BINGO!
If it's not that simple you're either running Royal Purple in your tranny or you're trying too hard LOL
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
when I go to put it in reverse and it dosent work I put it in first and than I put it in neutral and wiggle it a lil and than reverse and when that dosent work after I try it about 3 times I just let my hand brake down and let the car move up or back a lil bit and it dose right into reverse
Status
