What's the deal with USDM 550's?
rakkasan
Currahee!!
Fort Campbell, KY
Jon@935motorsports said:
I just had some 550cc US mkiv injectors sent out to RC for flow testing and cleaning and I also received a sheet that stated each injector only flowed 450cc. Anyone else?
LOL, mine too. I haven't seen any documented flow charts for 550's yet....
Boostage
323
Florida
rakkasan said:
So far, the only documented proof (flow charts) says that the purple tops are 450cc
so if people are making 500hp on whats really 450's. technically aftermarket 550's (that are actually 550's) should make 600hp.
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
Don't Go by the sheet to determine your Highest HP rating.
I put down 485 @ 22psi on my 1jz with a -15% on my AFC. Meaning
there is still room for growth. Stock ECU, no cams or any other internal mod.
Just stock fuel rail with the 550inj, AFPR and GT-40.
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
86_sports_1jz said:
how did you blow your 1j? was the injectors not feeding enough fuel making you run too lean?
431 you are well over 80% duty cycle on the 440's.
So one night I was toying around with the boost controller, did a few 3rd gear pulls on the hwy and never switched it back to were it was tune for.
The next day on the hwy I was running a few cars, was in 4th, hit 5th then BOOM....oil everywhere, white smoke inside my car..... it was a mess.
I leaned it out, pushing 19-20psi when 17 psi was the max I could run on my tune.
Learned my lesson My foot is too heavy and 400rwhp just doesn't do it for me no more so 440's will never be in any of my engines....
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
i was consistantly around 480 WHP on purple top mk4 injectors I never had any problems with my 1jz.... I did the 523 run once and back it down because when I added fuel pressure, I went leaner probably due to running out of fuel pump LPH @ high pressures.
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
I was on 93 pump.
