What the hell happened to the forums?
Status
Not open for further replies.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
MDCmotorsports said:
Been thinking about doing this for a long time when the right mk4 shell comes around....
a 98 is going to be kind of hard to find as a shell, look for a 93 or 94. if you are going 7m it wouldn't matter if its a tt or a NA.
Dont forget the r154 and the 800whp.
89.5+ mounts would make it a drop in ;)
OneJoeZee
Retired Post Whore
aboard the Argama
Element256 said:
You sure about that ?
Yes. Pretty sure... The motor mounts for the 7M changed in late 89. I assume the switch is the same time as the switch from 7M to 1JZ engine in Japan, so we naturally got the JZ compatible crossmember/engine mounts just with 7Ms. 1JZ and 2JZ will drop into the crossmember of an 89.5+ Supra. A 7M with the later style mounts should sit in a MK4 crossmember without modification. Run an R154, wire it up, and it should run...
I would rather blow up the MKIV in question than do that:biglaugh: , but the swap could be done I suppose.
Status
