I have a BHG...quite common so i wont ask what to do about that, i'm taking off the head myself, purchasing parts, and putting it back together after the head has been machined. I am NOT going for big HP...if anything i'll replace the intake because the rubber on mine is cracking around the clamping points and if i'm not careful it may leak. nothing more.
Questions;
I have white gunk in my oil passages, so far i have only dissasembled minor parts on the intake and hoses and i've seen it under the oil cap, in the PVC pipe (metal part that goes from the intake to the valve covers) and in the main oil tube that comes out of the right valve cover and goes down...somewhere. it's the big one at the very front of the cover.
WHAT should i do about that, i have heard that moisture will or can cause rod knock and i do not know for sure if there is moisture in my crankcase but i've drained it and and the oil didn't have the white sludge in it. I was hoping i could do something to prevent rod knock after i fix my headgasket...maybe somehow flush the crankcase and oil passages....i dont want to pull the engine, i have NO engine lift... and no job so money is a bit tight to spend on a lot stuff...but w/e i have to do.
When this was discovered i was running Prestone super flush through my cooling system for a flush which contains sodium citrate (68-04-2) and a friend mentioned that it could have harmed my engine internals because i left it in overnight instead of the 10 minutes of running its meant for (ran into a time issue). The following morning it's puffing white smoke once warmed up...damn it! does anyone know if this crap could have damaged my engine or water pump etc...?? It seemedto either burn much better than coolant and was eaiser to notice than coolant burning, or it just made the BHG worse.
I am starting full head dissasembly today, i have the hoses off and the intake it ready to come off. While it's apart should i shell out an extra 100 dollars for a whole Fel-pro gasket kit that includes every upper seal, or should i just get a head gasket? whats the best brand? i was thinking a toyota original or a Fel-pro... i dont know whats best..
last question; what needs to be removed in order to remove the oil pan? i was thinking that if i remove that i could see what's going on in there...
that's all for now...
Questions;
