of course this leaves.. what is figgie replacing the mechanical system with?
well, to bring the supra into the 21st century and doing it the way i do everything (overboard or better known as Obsessive compulsive Disorder)..
A MoTeC PDM32 digital based power distribution box.
so what does this little bundle of joy in combination do?
Well lets play the favorite "scenario" game....
crusing along minding my own business, when the grip reapers of alternators decides to take the alternator with it. In most case that would be manually killing anything and everything that is not essential to running the car. Well in this case, a logic condition and I automatically turn off everything save for
ECU, Dash, Ignition and fuel pump.
no? How about this one.
The car is running, the motor is so quiet you can not hear it. Ignition to on, one of the most awefull noises ever produced of metal on metal grinding. Well, with the RPM above a certain #, now I can keep the circuit from ever engaging while the motor is running!
Control my taillights, brake lights, emergency lights. Create a logic that if the alarm is set, disables the starter, Turns on one of the outputs to feed the MoTeC to limit RPM and SPEED and also use a different DBW slope that reaches a max of 30% opening.
Above all that, real time monitoring of current useage on a per channel basis.
All using M22759/91 wire (in my signature part of the Wire thread!).
