what does it take to get 500hp out of a 7mgte
suprahooked
Built 7M
Jun 20, 2006
1,160
pa
88redma70 said:
i got my motor out the car and cant decide what i wanna do and i have 3000 dollars to spend on it
Read my build thread i should be right around 500 but i have to finish the car.
88tsupra
143
long beach
I wouldn't know the best way to to reach 500+hp because I'm still around 200hp
But I know me and a friend plan on building up my bottom end first. While allowing me to still rebuild the head.
But then you have to think about the details.
Like will the clutch/flywheel/pressure plate hold up.
Drive shaft being 18+years old
etc etc
Try upgraded CT26-550cc injectors-walbro 255 fuel pump-exhaust-BIC DDP-Filter-
that right there sounds like it would please the power need for a little time
Doward
4,245
Alachua, FL
From bone stock?
Do a MHG, get some new 550cc injectors, a MAFT-Pro, a Wideband O2, new fuel pump, replacing anything rubber in the engine bay, and a CT26.
That'll run you close to $3000, and you should be able to get 350-400rwhp, reliably.
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
IJ. said:
$$$ then add some more $$$ and when it's just about right a few more $$$ can't hurt ;)
Bingo. The past year I've been coming home and losing 80% of every paycheck on my way through the garage into my house. I'm planning on 500hp on a budget build and I'm already past 5k at least, I still have at least another 1,500-2k to spend.
namkiii said:
7m = reliably
best thing would get a front clip of a 1jz supra and do the swap
I did not put this young man up to this IJ, I swear..........and for the record, he can't do the 1jz swap for $3000.00 either. He'd be better off building his 7m with some really good internals and replacing the stock oil pump with whatever it is you guys replace the stock oilpumps with............and then do lots and lots of praying and maybe sacrifice a virgin or two............:biglaugh:
steveyblack
529
Nj
just remember the classic rule
you can only pick 2 of these and you loose the 3rd one
reliability
performance
cheap
or something like that =P
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,965
suprahero said:
Damn you people!!!!!!!!
LEAVE JAY ALONE YOU BASTARDS!!!!! You are all just users and cheats and all yall want from him is more moremore!!!! Leave him alone :cry: He's torqueless, he knows it. He's only human. Leave him alone :wtc:
Ok, that's my Chris Crocker rant for the day:biglaugh:
Everyone with a 7m has taken one step backwards............in time. Get with new technology Ian...........:biglaugh:
