BoostMonger
PUSH IT TO THE LIMIT
Sep 5, 2011
880
Shadows of Utah
Took my needles off and got rid of the nasty faded yellow paint on them and paint them red, should look killer with white LEDs.
Sent From My HTC One S using Tapatalk 2
supra1jz
284
Auburn, Georgia, United States
Today I replaced my master brake cylinder in my 89 NA DD and flashed the whole brake system front and rear
Done
Also on another note while my other 89 1jz supra is at the body shop getting all pretty I have another friend to play with till she back.
Sep 19, 2011
510
Des Moines, IA
Drilled a hole in my intercooler pipe for my IAT sensor bung, and took the intercooler pipe and bung along with my tial wastegate flange and turbo manifold to my friends to have it tig welded. I am excited. I may get my AEM hooked up in MAP later on this week.
BoostMonger
Sep 5, 2011
880
Shadows of Utah
Zrain25;1910245 said:
How do u remove the needles... Do u have pics with the white leds I haven't put mine in
They just pull off, but you have to be very careful, the boost gauge and tach were really stuck on.
And Will, It came on the car :/
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,250
Charleston, SC
Installed one-way inline check valves on the IACV and PCV systems. This alleviated two major boost leaks. Also wired in my FAL fans into the AEM EMS and performed the 12v fuel pump relay mod for my Denso 285lph pump.
Here's a vid I took today. Idle is nice and steady and fans come on towards the end of the video at 190deg F.
Towing the car to Freed Engineering for a new dyno tune on Tuesday for the 720cc injectors. Hoping to lay down 500whp.
Doat
2,599
Houston, TX
She is at the shop getting a new clutch put in to find that the rear main seal is leaking, flywheel most likely needs to be replaced, and the oil pan gasket is could use replacing. Going to take a little longer to get her back than expected but will be worth it in the end.
Oh and it seems that the gasket for the tranny might be leaking a bit too
DOUBL3 D
458
Chesterfield,MO
www.facebook.com
I've seen it before lol I want one. Looks classy that's why I like it. With a tan interior....yummmmmy.
Only in my dreams for now haha
BoostMonger
Sep 5, 2011
880
Shadows of Utah
You've probably seen it from my other photos
Zrain25
639
Pelham,New Hampshire
Body guy started to paint the car . He did under the hood last night. I went with original color
ImageUploadedByTapatalk1359582701.484052.jpgImageUploadedByTapatalk1359582710.617704.jpg
He is gunna spray the car Saturday... This is how she looks right now on jack stands
Doat
2,599
Houston, TX
Quick question, I want to replace the seal for this piece because it seems that it is leaking a little bit.
I don't know if the seal for that is the input shaft seal on driftmotion or if it's that and something else.
