White Zombie
272
Hampton , VA
I bought a ShaftMasters driveshaft for my baby 3 days ago . It just came in the mail TODAY ! Wow what fast shipping ! I can't wait to install it . Pics soon ...
Numba1Stuna
361
Nampa, ID
Doat;1908280 said:
I can't even get it to the area where the numbers are when I set it all to TDC the mark is about an inch to the left of where the numbers start.
Does it the timing mark move at all when you rotate the CPS either direction? Is the CPS in there correctly?
Sent from my LG-P999 using Tapatalk 2
Doat
2,599
Houston, TX
Yea it moves the mark and I made sure the CPS went in correctly because I slowly slid it in with ease and pulled it out to check that it was still lined up. I highly doubt my timing belt is incorrect because if it was off the car would run like crap but the car runs fine. When my CPS cover comes in I'll set the motor to TDC again and remove the cap and watch the gears as I put it in but is there anything else I should check?
Numba1Stuna
361
Nampa, ID
Backlash2032;1908346 said:
Remove the cs pulley and see if the key failed.
Sent from my terrible HTC Rezound using Tapatalk. Don't buy HTC...
That's another thought I had... Mine failed on the 90. It was all hogged out...
Doat
2,599
Houston, TX
That flew right over my head lol elaborate please
White Zombie
272
Hampton , VA
I'm sure he meant that the key way on the crankshaft became wider that the key ! Hence "hogged out" . Then the crank pulley will wander around and make the timing marks look like their bouncing ...
mecevans
1,295
M-bay, cali
New wheel bearings. Brembo rotors. Ebc redstuff. Goodridge lines. Ate super blue racing fluid. All new hardware. 0 thousandths runout. :) Replaced like 5 bulbs.
supra1jz
284
Auburn, Georgia, United States
Backlash2032;1908373 said:
How much did you pay? I paid 80 something shipped for mine from driftmotion
If you are asking me I paid 85 shipped to my house in 2 days DM would of been 93 shipped to my house but have to wait over a week and I'm sick of having to pay so much for a week wait when elmhurst just charged 9 dollars for shipping
Numba1Stuna
361
Nampa, ID
Exactly, that crankshaft
now needs machine work to hold the key again, and the edge of the key wore out and is rounded down.
Doat;1908425 said:
Ah I got ya, so remove the pulley and check the key for damage or something?
The key can be replaced, but the little rectangle section of the crankshaft is what holds it secure in place and mine is worn out. I'll have to take a picture and show you what to look for.
I also finally brought my new Supra home tonight. Its overheating... Changed out the thermostat and she is still hot. I've got a new water pump for it, I'll change that tomorrow.
Doat
2,599
Houston, TX
I just love you man, I am a very visual person if someone can show me what to look for and such then I fully understand and know what I am doing. If the key is worn then what do I have to do from there?
Numba1Stuna
361
Nampa, ID
Lol, thanks. I try to be of help :) If the key needs replaced, it's simple, just stick another one in. If it's not, then the crankshaft needs some machine work on the grooves that hold the key. I'll take pics of my hogged out crank tonight after work.
