MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,249
Charleston, SC
Was the 2nd and 3rd run after fixing blowout? There's still a big dip in power, but not nearly as bad as the first run. It also looks a little lean from 5-6k. Maybe I'm crazy, but I'd want that closer to 11.5 throughout that range.
I diagnosed and resolved the spark blowout issue a couple days after picking the vehicle up from the tuner. He was saying the power dip was likely due to the restrictive factory exhaust manifold, however, I have never seen that power drop on any of my past dyno runs. As soon as I drove the vehicle home, the engine would sputter under full boost and even backfire. That's when I realized it was spark blowout. After tightening the plug gap it pulled like a sonovabitch all the way through redline. Unfortunately, now I'm seeing 10.3 afr under full boost, which is hella rich. I just don't feel like taking it back to the tuners since I've been without it for so long. It's running great and I don't have to worry about going lean under boost if there's a spike or anything. Eventually I'm going to have to get it back on a dyno and lean it out a bit. Wonder how much power that spark blowout and rich afr was affecting my numbers?
I did notice that lean range on the dyno chart from 5-6k. That may be from the spark blowout since that was the rpm range were the engine was sputtering for me. Unburnt fuel will not cause the wb read rich, but lean. With my forged internals I'm not too concerned, but I'll need to pay attention to my wideband readings on my next drive.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
I diagnosed and resolved the spark blowout issue a couple days after picking the vehicle up from the tuner. He was saying the power dip was likely due to the restrictive factory exhaust manifold, however, I have never seen that power did on any of my past dyno runs. As soon as I drove the vehicle home, the engine would sputter under full boost and even backfire. That's when I realized it was spark blowout. After tightening the plug gap it pulled like a sonovabitch all the way through redline. Unfortunately, now I'm seeing 10.3 afr under full boost, which is hella rich. I just don't feel like taking it back to the tuners since I've been without it for so long. It's running great and I don't have to worry about going lean under boost if there's a spike or anything. Eventually I'm going to have to get it back on a dyno and lean it out a bit. Wonder how much power that spark blowout and rich afr was affecting my numbers?
Good point on the misfire showing as lean. I don't think you were overly rich through the rest of the powerband though. I'd rather be a little rich than a little lean. ;)
Asterix
Lurker of Power
Vienna, VA
Yesterday, I installed an outside temperature display that I've wanted for a while. I put the sensor under the right headlamp in front of the intake, zip-tied to an AC pipe. I hoped it would be more consistent because of the air flow, but I may try it in front of the radiator. The temperature goes up a few degrees while I'm sitting at a stoplight.
I like the green LED display as it matches the stock stuff, but it's a bit bright, and not adjustable. I just tapped into the cigar lighter power to run it. It uses under 10milliAmps.
Maybe if the Fahrenheit version ever becomes available I'll swap it out. Meanwhile, I get to learn Celsius. This was the smallest display I could find on Amazon.
te72
Classifieds Moderator
6,610
7
WHYoming
Little piece of tint over the display should cure that brightness issue, if you can get it to stick. If not, can use VHT Niteshade, just make sure the display face is absolutely clean before you spray...
As far as the temp itself goes, are you sure that's in celsius? That's a touch high for February in the northern hemisphere...
Asterix
Lurker of Power
Vienna, VA
I "painted" it with a black Sharpie after I took the photo, but I will look for a better solution, like a wee piece of tint film.
It was 6.9C in my garage when I took the picture. The sun on the door warms it up nicely.
plaaya69
87T Supra
Nov 18, 2006
947
7
Lake County, IL
Nice Asterix, never seen a mk3 with a outside temp display. You might find a good spot to mount the temp sensor next to the ambient temp sensor under the front horns in the middle next to the coolant reservoir.
Doat
2,599
Houston, TX
Trying to figure out a good brand of coilovers or strut setup for my car
I have BC racing coilovers with swift springs and I love them and pretty affordable. I got mine for about $1200ish.
After about a year of it sitting in the garage with a BHG I was finally able to get to the point of starting the tear down. I got a second head, had it surfaced and heli-coiled the exhaust threads then when I remove my current head I am going to swap over the cams and valves, lap the valves, change all of the seals and gaskets, and slap it back together with an ECUmasters DET3 piggy back. This is the progress I've made over last weekend and I am surprised I got as far as I did in a couple days considering the last time I did this was about 5 years ago without resurfacing the head. I cannot wait to get back in this baby and boost again I've missed it so much and am very excited to see the results this time after the MAF is removed and a tune.
Asterix
Lurker of Power
Vienna, VA
It just hit me that the decimal point is hard to see in my photo... No, it wasn't 69C in my garage in February. That's way over the highest temperature ever recorded on the surface of Earth.
:aigo: :evil5: ::flame::
SupraKid
138
Santa Teresa, NM
Got a garage goodie to frame and hang up. 1987 article of a look alike of my car.:sonic::sonic:
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
Had a friend take a few pictures next to a pretty cool partial submarine in town.
Put some Firestone Firehawk Indy 500 275/40 tires on the back. They sure perform a lot better than the other coopers
Also broke the transmission... Parts on the way!
Sent from my XT1635-01 using Tapatalk
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
Assembled the r154. Seems to shift fine on the bench, but it's the first transmission I've rebuilt. We'll see how it goesIMG_20180302_232703178.jpgIMG_20180301_175018388.jpg
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
you better have put the upgraded thrust washer in there! i rebuilt mine with the upgraded retainer, washer, and shift forks. its held up great handle lots of launches at the track. the main thing with doing the trans is making sure everything is seated enough when pressing things together. then also measure your snap rings and get the proper one to make things as tight as possible. usually the one you pull out doesn't fit right after reassembly.
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
Oh definitely did! I got the mc shift fork, thrust washer, and retainer. I didn't measure the snap rings though, I tore everything down and reassembled. If I have any issues down the road I'll just have to open it up again. It was my first transmission rebuild but so far it shifts like butter!
I had a leaky input shaft seal and it soaked my clutch disk so I took it back out and replaced the seal. I also went with the ACT ceramic 4 puck this round. I hear they are just a little lighter and hold a little more torque as well. We'll see
