Doat
2,599
Houston, TX
Silver MK3;1960044 said:
How did that go? I should probably do my timing belt soon and may do the water pump at the same time.
It's not hard just back breaking because you are bent over the entire time I got to the point of removing the old timing belt within 2 hours I could have done it faster if I wasn't cleaning up the old gasket from the water pump or even dealing with removing the water pump itself. If you want to just replace the timing belt you can remove the old one in less than 2 hours easily especially if you have done it before. I broke the connector on one of the temperature sensors on the thermostat housing, not the one toward the front of the house the one that is inside of the power steering reservoir bracket below a green connector.
gsxr141
1,158
10
rochester
just ordered a bunch of stuff from driftmotion. :) totally forgot to order another t-shirt :(
polished the lower timing cover, thermostat housing and a few other bits.
getting ready to order a headgasket and whatever other ones i need. :)
Austin2048
209
Kaukauna, Wi
Anyone ever strap a queen size mattress to the roof of their supra? I'm debating doing it right now if I can't find someone with a truck
Sent from my Desire HD using Tapatalk 4 Beta
yhatzee89
Joe Yantz
Aug 31, 2012
977
San Antonio, TX
...do it... You know you want to...
Drove mine to defensive driver class today :/
Doat
2,599
Houston, TX
Finally got the car running, timed nearly right will have to borrow my friend's light to time it perfectly, no leaks but I cannot tell what my temperature is because I broke my damn connector for the gauge. I installed the DDP the part that connects to the rest of the exhaust isn't oval enough you have to modify that flange to get it to fit to the stock exhaust. It sounds like a total beast now best $200 I've spent. I will post up a video later tonight after I shower and get something to eat, haven't had anything to eat literally all day I just worked on the car and drank a powerade.
Backlash2032
1,823
Nebraska
If you just get a female spade connector that will work for the temp gauge.
Sent from my HTC Droid DNA
Doat
2,599
Houston, TX
Zrain25;1960121 said:
It's weird when I have to do a bunch if shit on the car or in general I don't eat either lol. But sitting on the couch I eat all day hahaha
It happens with me every time I work on the car.
I still have it but it ripped or broke at the wire and there isn't enough wire sticking out of the spade connector to solder it back together.
Doat
2,599
Houston, TX
Backlash2032;1960132 said:
Just strip the wire and crimp on a new female spade terminal..
yea I plan on doing that when I get a female spade that has some wiring sticking out of the connector or whatever. I may just use one from my accord since I never use that car and it will never overheat lol. I did hit fuel cut though when I took the car out for a spin with the DDP but a friend of mine is going to sell me a blitz boost controller.
Here is a quick video I made on the way home, should have gone higher up with the revs but I thought there was a cop going the opposite direction.
http://www.facebook.com/photo.php?v=10200557032430474&l=1659619837368574033
Silver MK3
1,517
Madison, AL
Alright, cool. I haven't taken it off before, but things like this seem to usually go pretty well if you follow the TSRM. Its when you get into the modifications/upgrades that things can start to not go together so well. Or so it seems...
Doat
2,599
Houston, TX
Yea I found that out today lol this is my first modification I've done to a car and the first real mod for the supra other than an intake for the turbo.
Backlash2032
1,823
Nebraska
I'm talking about the generic ones. You buy them in packs of like 20 and crimp them on?
Silver MK3
1,517
Madison, AL
That's why I'm happy with my N/A Supra. There isn't a whole lot to modify so it just stays as my good looking cruiser/GT car.
Doat
2,599
Houston, TX
Yea I see what you mean but those are just the connectors itself I need the connector with the wire inside of it and some of it sticking out so I can crimp the exposed wire I have to it unless what you are talking about is exactly that?
I know what you mean but turbo is better lol
Faye
where's my tiara?
Apr 30, 2013
555
San Antonio, TX
www.youtube.com
Had mine painted!!!
Before:
After:
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
While my '89 was NA, I built it into a very nice IASCA SQ car. It was something that I could do. It doens't have a whole lot of that left in it. After I got the turbo engine, someone broke in and ripped out most of the good stuff. I kind of patched it back together to have music, but I never rebuilt the system properly. I was pretty happy with the NA Supra... But not enough to pass on the opportunity to buy and install a 7M-GTE.
I discovered that a V8 GM fuel pump blockoff plate is identical to the J tube blockoff plate. (Of course the J tube goes where the mechanical fuel pump went in the pre EFI days. It used to be driven off of a cam on the oil pump driveshaft. A distributor used to be driven off of that, too. The gear is still there for it.) My guess is that the mechanical fuel pump was probably very similar if not identical to the GM one. I recognised the pattern a long time ago, but today I determined that they are in fact identical in bolt pattern and shape. Nice thing about the ones for the GM is that they're cheap, and I can just pick one off the rack at the local parts shop.
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
Reupholstered my door panel trim pieces in black Swede. I think they turned out pretty good
I also reinforced the armrest with fiberglass
Sent from my PC36100 using Tapatalk 2
yhatzee89
Joe Yantz
Aug 31, 2012
977
San Antonio, TX
I wanna do this as well, I don't have any issues with my arm rests ATM, but I wanna prevent having any down the line. My old 87 my buddy put his elbow through the passenger side one :/
