Grandavi;1947935 said:Dual?
Doat;1947942 said:I think my CPS is leaking oil I may be buying the rebuild kit on DM to fix it. Is it hard to do? I am afraid of the drilling part mostly.
Dan_Gyoba;1947984 said:Before rebuilding the CPS, why not try just replacing the O ring to see if it's that? It's a simple enough operation to replace the O ring (Just have to set #1 TDC so you don't mess up the timing) and it could well solve the problem for you.
Oh, and for practical... Any hatchback should be able to carry a bunch of stuff. I totally floored my sister with the amount of Ikea shelving that I was able to transport in mine.![]()
Yea I plan on doing that when I install my boost controller and if it's not leaking inside then I'll order an O ring from the dealer.suprarx7nut;1948010 said:Just pop the cover off and check for oil. If you find any oil in the cover/housing its time to replace the inner seal and bearing.
Sent from my Galaxy Nexus using Tapatalk 2
Grandavi;1947207 said:I like that. Is that built from scratch? Where will it sit?
akito;1948036 said:Found out why my new supra wasn't running after swap
https://www.facebook.com/photo.php?fbid=10200787666788043&set=gm.10151726480576788&type=1&theater
Enjoyed. Props to Dirgle and 3p141592654 for guiding me through this mess. Sorry it's a FB picture. Have a TT pump going in but i'm waiting for the fuel filter from the dealer.
