Devil you know > Devil you don't.Shane;1947773 said:Not sure if it would be better to try to save mine or swap in a jdm counterpart.
Been there lol I got pissed off enough one night and got a replacement pad from rockauto then later on I freaking found the original one in my damn trunk of all places wedged in between the spare tire.BrandonW;1947787 said:got another rubber cover for my clutch pedal have been without one for like 3 years lol since the original one wore through
it sucked if my shoe was ever wet
Dan_Gyoba;1947776 said:Devil you know > Devil you don't.
Shane;1947831 said:Quite true. There is also the ever present urge (as a redneck at heart) to somehow stuff that '73 Pontiac 400ci + trans sitting in my garage, into my poor little Supra. Lol but I think the best solution would be getting another 7M to rebuild while mine slowly dies. It still has tons of power just sounds really bad and idles funky.
Supraguy7M;1947850 said:Check your valve adjustment and do a compression test. You may just b hearing abnormal amounts of lifter tick, and burning oil thru worn valve seals. Never know, you may have a more solid motor right now then you think.
Sounds like a good idea. I may look into the valves and compression while I'm doing my water pump next weekend.
gsxr141;1947856 said:hey. my car smokes sometimes, idles rough sometimes, and has had a noise at around 2200rpm for the last 2 years. even with all that it runs strong, and just put down 270/370 with only minor mods. when it dies i'll build another motor.
Sounds about right, 2200-2800 and more pronounced when warm and varies with throttle.
A "tinish" rattle/ticking sound.
Shane;1947859 said:Sounds about right, 2200-2800 and more pronounced when warm and varies with throttle.
A "tinish" rattle/ticking sound.[/QUOTE
Definitely sounds like lifters to me. I'm not an expert though. A more pronounced thump/knock would b lower end. Tinish sort of ticking sound sound seems like it would b in the valvetrain.
Shane;1947886 said:Nice, what are you going to do with the saw blades?
