leezymk3
125
nashville
i can feel the hot coming out,
maybe i should put a temp gauge and see the different
before i prope my hood,i can feel the heat inside the car,
now i cant,and i drive it all day in tn weather to day was high 70ish
Backlash2032
1,823
Nebraska
The base of the windshield is a high pressure area. It won't do anything at speed. At low speeds it may do some, but a factory cooling system in good shape with air blockers in place will do just fine.
Sent from my HTC6435LVW using Tapatalk 2
leezymk3
125
nashville
gsxr141;1934473 said:
most of the problem is at idle. anything to get some heat out of there. :)
im planing on buy a turbo blanket,and heat wrap the dp,,,on black friday,cuz black friday sale is awesome
this turbo burning up that bay,with heat,with the hood prope help out alot
whitehat89
227
San Antonio, Texas, United States
That's awesome, Doat!
I ordered an OEM EGR cooler gasket, mine is leaking. Also, how much would that gasket leaking affect boost? Ever since it started leaking, I havent seen over about 4lbs, a little under the middle mark on my boost gauge. Im assuming they are related, just not sure if there might be a second related issue.
Sent via my awesome rooted S3 on TapaTalk
Doat
2,599
Houston, TX
Wouldn't a leaking EGR gasket be like having an exhaust leak? I'd fix that problem before hitting boost just to be on the safe side because when I had an exhaust leak I couldn't hit full boost either so I played it safe and replaced the gasket and torque the nuts properly then have fun with the turbo.
Drake69
Enjoyin' mah ride...
Aug 24, 2009
648
Richmond, Virginia, United States
Videos!
[video=youtube;AbkcH80Iil0]http://www.youtube.com/watch?v=AbkcH80Iil0[/video]
[video=youtube;fjHRfLErTSo]http://www.youtube.com/watch?v=fjHRfLErTSo[/video]
First vid was the very first time we turned her over. The revving you hear is a vacuum line that was forgotten towards the back of the motor. And the second vid just speaks for itself.
We had an issue with one of the gas lines leaking where it turns upward to the engine, so Seth fixed it with another adapter piece. Oil pan leaked when we ran oil inside the motor, but that was because the drainplug wasn't tight. Simple stuff.
Now we'll be putting in all the coolant stuff like rad, fans, hoses, etc..., getting the wiring shielded, ECU and igniter mounted and shielded, the fuse box mounted, and the extra gauges installed. Once all that is done we start tuning her.
Just a little more to go
