Just accidentally punched a hole in the '89's gas tank. The ground underneath it is a lot softer than I thought, and when I tried to settle the rear onto the jack stands (With angle iron underneath them, which was adequate before) the stands pitched forward, and the jack head went from under the differential to the gas tank. Next thing I'm smelling gas.
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I guess a gas tank is also on the shopping list for the '89 when it's time to put it all together.
The '90 is going to be getting more pampering, since it's the one that's going to get the go-fast goodies. Lots of these will be removed from the '89 this summer. Once I get it up on stands, my intent is that it will stay there for a while. There are some things that I'm debating. I might leave the Lexus AFM and 550cc injectors in it, if a set of injectors is in the budget for the '90, to use in conjunction with the Apexi Neo, but I'll take them for now, if that's not in the budget for getting the 7M on the engine stand finished this summer. I'm certainly taking the Stage 3 clutch, since the '90 needs a clutch now. I'll also take the exhaust now, since I have to drop it to remove the clutch. Might as well put on the one I want. Over the summer, I'll remove the turbo from the '89. I plan on switching the radiator over as well, since the '89 probably isn't going anywhere for a year, and I might as well get some use from the Koyo. I'll probably be taking pieces from the sound system in the '89 as well, though I plan on doing a new speaker setup, I like the head unit in the '89 better than the new ones that I can buy.
